AW: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
    Schönhammer, Herbert
    Schoenhammer.Herbert at Regensburg.de
    Tue Nov  4 07:12:56 EST 2008
Hello Christoph, hello Mr. Scholle,
phpinfo() does NOT list a DOM-library.
Reading the doc's in http://de2.php.net/manual/de/dom.setup.php no specail library should be installed. Only the php-xml module should be installed.
phpinfo() says:
php Version 5.2.5
configure-Settings are: ..., '--enable-libxml'... '--enable-xml' '--enable-simplexml' ...
libXML Support: active
libXML Version 2.6.23
libXML streams: enabled
greetings
Herbert Schoenhammer
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Christoph Baudson
>Gesendet: Dienstag, 4. November 2008 12:54
>An: Mapbender User List
>Betreff: Re: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>Hello,
>do you have the DOM library installed in PHP? Just check via phpinfo().
>Christoph Baudson
>Schönhammer schrieb:
>> Hello Mr. Scholle,
>> thank you for your reply.
>> I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
>> I've tried now FF 3.x, IE7 and now the latest Opera. It's
>all the same.
>> But I had just a look in the webserver error_log. I get the following
>> error-message when saving the the wmc:
>>  PHP Fatal error:  Class 'DOMDocument' not found in
>> /home/mapbender/mapbender_2.5/http/classes/class_wmc.php on line 239
>> Will a developper or something else have a tipp for further
>"researches" ?
>> Thanks
>> *Von:* mapbender_users-bounces at lists.osgeo.org
>> [mailto:mapbender_users-bounces at lists.osgeo.org] *Im Auftrag von
>> *Burghardt.Scholle at stadt.wolfsburg.de
>> *Gesendet:* Dienstag, 4. November 2008 08:37
>> *An:* mapbender_users at lists.osgeo.org
>> *Betreff:* AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>>     Hello Mr. Schönhammer,
>>     I still have the same problems in a system combination
>with Ubuntu
>>     8.04 (Server) and the IE6 (Client). With FF or IE7 I don't have
>>     any Problems. In a system combination Debian Etch/Lenny (Server)
>>     and any Browser I don't have any problems with save/load WMC too.
>>     Perhaps you can try another combination to test the behavior of
>>     the module mod_savewmc.php. Unfortunately I don't know a solution
>>     for the first combination.
>>     Greetings
>>     Burghardt Scholle
>>         [mailto:mapbender_users-bounces at lists.osgeo.org]*Im Auftrag
>>         von *Schönhammer, Herbert
>>         *Gesendet:* Dienstag, 4. November 2008 08:16
>>         *Betreff:* [Mapbender-users] MB 2.5: Error in
>saveWMC / loadWMC
>>         Hi list,
>>         I want to generate a WMC-Document with MB 2.5 using
>the module
>>         mod_savewmc.php.
>>         Clicking the button "Save workspace as Web Map Context
>>         Document" I am asked for the name of the workspace.
>>         And that was all.
>>         The wmc-document ist not offered using module
>mod_loadwmc.php.
>>         MapBender does not create an entry in mb_error_logs.
>>         I don't find any record in the table mb_user_wmc or any file
>>         on the server or an my client.
>>         I have tried all combinations with the var saveInSession:
>>         - the var was set / unset
>>         - the var was filled with the values 0/1
>>         - the var was filled with the values true/false
>>         The behaviour is reproducable with the shipped guis
>gui1 and gui2.
>>         Where is the problem ?
>>         Has anybody a solution for me ?
>>         Greetings
>>         Schönhammer Herbert
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>Where2B-Konferenz
>Die Geo-IT Konferenz der WhereGroup
>vom 9.-10. Dezember 2008 in Bonn
>Web: www.where2b-conference.com
>W h e r e G r o u p GmbH & Co. KG
>Siemensstraße 8
>53121 Bonn
>Germany
>Christoph Baudson
>Anwendungsentwickler
>Fon: +49 (0)228 / 90 90 38 - 15
>Fax: +49 (0)228 / 90 90 38 - 11
>christoph.baudson at wheregroup.com
>www.wheregroup.com
>Amtsgericht Bonn, HRA 6788
>Komplementärin:
>WhereGroup Verwaltungs GmbH
>vertreten durch:
>Olaf Knopp, Peter Stamm
More information about the Mapbender_users
