AW: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Christoph Baudson
christoph.baudson at wheregroup.com
Tue Nov 4 07:44:25 EST 2008
Thanks for your reply. My PHP installation lists the DOM library as follows
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.6.30
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
I'm using PHP 5.2.3. What PHP version are you using? What is your server OS?
Thanks
Christoph Baudson
Schönhammer schrieb:
> Hello Christoph, hello Mr. Scholle,
> phpinfo() does NOT list a DOM-library.
> Reading the doc's in http://de2.php.net/manual/de/dom.setup.php no specail library should be installed. Only the php-xml module should be installed.
> phpinfo() says:
> php Version 5.2.5
> configure-Settings are: ..., '--enable-libxml'... '--enable-xml' '--enable-simplexml' ...
> libXML Support: active
> libXML Version 2.6.23
> libXML streams: enabled
> greetings
> Herbert Schoenhammer
>> -----Ursprüngliche Nachricht-----
>> Von: mapbender_users-bounces at lists.osgeo.org
>> [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>> von Christoph Baudson
>> Gesendet: Dienstag, 4. November 2008 12:54
>> An: Mapbender User List
>> Betreff: Re: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>> Hello,
>> do you have the DOM library installed in PHP? Just check via phpinfo().
>> Christoph Baudson
>>> Hello Mr. Scholle,
>>> thank you for your reply.
>>> I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
>>> I've tried now FF 3.x, IE7 and now the latest Opera. It's
>> all the same.
>>> But I had just a look in the webserver error_log. I get the following
>>> error-message when saving the the wmc:
>>> PHP Fatal error: Class 'DOMDocument' not found in
>>> /home/mapbender/mapbender_2.5/http/classes/class_wmc.php on line 239
>>> Will a developper or something else have a tipp for further
>> "researches" ?
>>> Thanks
>>> *Von:* mapbender_users-bounces at lists.osgeo.org
>>> [mailto:mapbender_users-bounces at lists.osgeo.org] *Im Auftrag von
>>> *Burghardt.Scholle at stadt.wolfsburg.de
>>> *Gesendet:* Dienstag, 4. November 2008 08:37
>>> *An:* mapbender_users at lists.osgeo.org
>>> *Betreff:* AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>>> Hello Mr. Schönhammer,
>>> I still have the same problems in a system combination
>> with Ubuntu
>>> 8.04 (Server) and the IE6 (Client). With FF or IE7 I don't have
>>> any Problems. In a system combination Debian Etch/Lenny (Server)
>>> and any Browser I don't have any problems with save/load WMC too.
>>> Perhaps you can try another combination to test the behavior of
>>> the module mod_savewmc.php. Unfortunately I don't know a solution
>>> for the first combination.
>>> Greetings
>>> Burghardt Scholle
>>> [mailto:mapbender_users-bounces at lists.osgeo.org]*Im Auftrag
>>> von *Schönhammer, Herbert
>>> *Gesendet:* Dienstag, 4. November 2008 08:16
>>> *Betreff:* [Mapbender-users] MB 2.5: Error in
>> saveWMC / loadWMC
>>> Hi list,
>>> I want to generate a WMC-Document with MB 2.5 using
>> the module
>>> mod_savewmc.php.
>>> Clicking the button "Save workspace as Web Map Context
>>> Document" I am asked for the name of the workspace.
>>> And that was all.
>>> The wmc-document ist not offered using module
>> mod_loadwmc.php.
>>> MapBender does not create an entry in mb_error_logs.
>>> I don't find any record in the table mb_user_wmc or any file
>>> on the server or an my client.
>>> I have tried all combinations with the var saveInSession:
>>> - the var was set / unset
>>> - the var was filled with the values 0/1
>>> - the var was filled with the values true/false
>>> The behaviour is reproducable with the shipped guis
>> gui1 and gui2.
>>> Where is the problem ?
>>> Has anybody a solution for me ?
>>> Greetings
>>> Schönhammer Herbert
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Where2B-Konferenz
>> Die Geo-IT Konferenz der WhereGroup
>> vom 9.-10. Dezember 2008 in Bonn
>> Web: www.where2b-conference.com
>> W h e r e G r o u p GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> Anwendungsentwickler
>> Fon: +49 (0)228 / 90 90 38 - 15
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
Where2B-Konferenz
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_users
