AW: AW: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Schönhammer, Herbert
Schoenhammer.Herbert at Regensburg.de
Tue Nov 4 07:53:30 EST 2008
Hello,
I'm using php Version 5.2.5, libxml Version 2.6.23 and Server OS is SuSE Linux Enterprise Server 10.
Greetings
Herbert Schoenhammer
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Christoph Baudson
>Gesendet: Dienstag, 4. November 2008 13:44
>An: Mapbender User List
>Betreff: Re: AW: AW: [Mapbender-users] MB 2.5: Error in
>saveWMC / loadWMC
>Thanks for your reply. My PHP installation lists the DOM
>library as follows
>dom
>DOM/XML enabled
>DOM/XML API Version 20031129
>libxml Version 2.6.30
>HTML Support enabled
>XPath Support enabled
>XPointer Support enabled
>Schema Support enabled
>RelaxNG Support enabled
>I'm using PHP 5.2.3. What PHP version are you using? What is
>your server OS?
>Thanks
>Christoph Baudson
>Schönhammer schrieb:
>> Hello Christoph, hello Mr. Scholle,
>> phpinfo() does NOT list a DOM-library.
>> Reading the doc's in
>http://de2.php.net/manual/de/dom.setup.php no specail library
>should be installed. Only the php-xml module should be installed.
>> phpinfo() says:
>> php Version 5.2.5
>> configure-Settings are: ..., '--enable-libxml'...
>'--enable-xml' '--enable-simplexml' ...
>> libXML Support: active
>> libXML Version 2.6.23
>> libXML streams: enabled
>> greetings
>>> Gesendet: Dienstag, 4. November 2008 12:54
>>> Betreff: Re: AW: [Mapbender-users] MB 2.5: Error in saveWMC
>/ loadWMC
>>> Hello,
>>> do you have the DOM library installed in PHP? Just check
>via phpinfo().
>>> Christoph Baudson
>>>> Hello Mr. Scholle,
>>>> thank you for your reply.
>>>> I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
>>>> I've tried now FF 3.x, IE7 and now the latest Opera. It's
>>> all the same.
>>>> But I had just a look in the webserver error_log. I get
>the following
>>>> error-message when saving the the wmc:
>>>> PHP Fatal error: Class 'DOMDocument' not found in
>>>> /home/mapbender/mapbender_2.5/http/classes/class_wmc.php
>on line 239
>>>> Will a developper or something else have a tipp for further
>>> "researches" ?
>>>> Thanks
>>>> *Von:* mapbender_users-bounces at lists.osgeo.org
>>>> [mailto:mapbender_users-bounces at lists.osgeo.org] *Im Auftrag von
>>>> *Burghardt.Scholle at stadt.wolfsburg.de
>>>> *Gesendet:* Dienstag, 4. November 2008 08:37
>>>> *An:* mapbender_users at lists.osgeo.org
>>>> *Betreff:* AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>>>> Hello Mr. Schönhammer,
>>>> I still have the same problems in a system combination
>>> with Ubuntu
>>>> 8.04 (Server) and the IE6 (Client). With FF or IE7 I don't have
>>>> any Problems. In a system combination Debian
>Etch/Lenny (Server)
>>>> and any Browser I don't have any problems with
>save/load WMC too.
>>>> Perhaps you can try another combination to test the behavior of
>>>> the module mod_savewmc.php. Unfortunately I don't know
>a solution
>>>> for the first combination.
>>>> Greetings
>>>> Burghardt Scholle
>>>> [mailto:mapbender_users-bounces at lists.osgeo.org]*Im Auftrag
>>>> von *Schönhammer, Herbert
>>>> *Gesendet:* Dienstag, 4. November 2008 08:16
>>>> *Betreff:* [Mapbender-users] MB 2.5: Error in
>>> saveWMC / loadWMC
>>>> Hi list,
>>>> I want to generate a WMC-Document with MB 2.5 using
>>> the module
>>>> mod_savewmc.php.
>>>> Clicking the button "Save workspace as Web Map Context
>>>> Document" I am asked for the name of the workspace.
>>>> And that was all.
>>>> The wmc-document ist not offered using module
>>> mod_loadwmc.php.
>>>> MapBender does not create an entry in mb_error_logs.
>>>> I don't find any record in the table mb_user_wmc
>or any file
>>>> on the server or an my client.
>>>> I have tried all combinations with the var saveInSession:
>>>> - the var was set / unset
>>>> - the var was filled with the values 0/1
>>>> - the var was filled with the values true/false
>>>> The behaviour is reproducable with the shipped guis
>>> gui1 and gui2.
>>>> Where is the problem ?
>>>> Has anybody a solution for me ?
>>>> Greetings
>>>> Schönhammer Herbert
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Where2B-Konferenz
>>> Die Geo-IT Konferenz der WhereGroup
>>> vom 9.-10. Dezember 2008 in Bonn
>>> Web: www.where2b-conference.com
>>> W h e r e G r o u p GmbH & Co. KG
>>> Siemensstraße 8
>>> 53121 Bonn
>>> Germany
>>> Christoph Baudson
>>> Anwendungsentwickler
>>> Fon: +49 (0)228 / 90 90 38 - 15
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> christoph.baudson at wheregroup.com
>>> www.wheregroup.com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
>Where2B-Konferenz
>Siemensstraße 8
>53121 Bonn
>Germany
>Christoph Baudson
>www.wheregroup.com
>Komplementärin:
>vertreten durch:
More information about the Mapbender_users
