AW: AW: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Marco Lechner
marco.lechner at geographie.uni-freiburg.de
Tue Nov 4 08:00:17 EST 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
try installing php5-dom package
Marco
Schönhammer schrieb:
> Hello,
> I'm using php Version 5.2.5, libxml Version 2.6.23 and Server OS is
SuSE Linux Enterprise Server 10.
> Greetings
> Herbert Schoenhammer
>> -----Ursprüngliche Nachricht-----
>> Von: mapbender_users-bounces at lists.osgeo.org
>> [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>> von Christoph Baudson
>> Gesendet: Dienstag, 4. November 2008 13:44
>> An: Mapbender User List
>> Betreff: Re: AW: AW: [Mapbender-users] MB 2.5: Error in
>> saveWMC / loadWMC
>> Thanks for your reply. My PHP installation lists the DOM
>> library as follows
>> dom
>> DOM/XML enabled
>> DOM/XML API Version 20031129
>> libxml Version 2.6.30
>> HTML Support enabled
>> XPath Support enabled
>> XPointer Support enabled
>> Schema Support enabled
>> RelaxNG Support enabled
>> I'm using PHP 5.2.3. What PHP version are you using? What is
>> your server OS?
>> Thanks
>> Christoph Baudson
>>> Hello Christoph, hello Mr. Scholle,
>>> phpinfo() does NOT list a DOM-library.
>>> Reading the doc's in
>> http://de2.php.net/manual/de/dom.setup.php no specail library
>> should be installed. Only the php-xml module should be installed.
>>> phpinfo() says:
>>> php Version 5.2.5
>>> configure-Settings are: ..., '--enable-libxml'...
>> '--enable-xml' '--enable-simplexml' ...
>>> libXML Support: active
>>> libXML Version 2.6.23
>>> libXML streams: enabled
>>> greetings
>>>> Gesendet: Dienstag, 4. November 2008 12:54
>>>> Betreff: Re: AW: [Mapbender-users] MB 2.5: Error in saveWMC
>> / loadWMC
>>>> Hello,
>>>> do you have the DOM library installed in PHP? Just check
>> via phpinfo().
>>>> Christoph Baudson
>>>>> Hello Mr. Scholle,
>>>>> thank you for your reply.
>>>>> I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
>>>>> I've tried now FF 3.x, IE7 and now the latest Opera. It's
>>>> all the same.
>>>>> But I had just a look in the webserver error_log. I get
>> the following
>>>>> error-message when saving the the wmc:
>>>>> PHP Fatal error: Class 'DOMDocument' not found in
>>>>> /home/mapbender/mapbender_2.5/http/classes/class_wmc.php
>> on line 239
>>>>> Will a developper or something else have a tipp for further
>>>> "researches" ?
>>>>> Thanks
>>>>> *Von:* mapbender_users-bounces at lists.osgeo.org
>>>>> [mailto:mapbender_users-bounces at lists.osgeo.org] *Im Auftrag von
>>>>> *Burghardt.Scholle at stadt.wolfsburg.de
>>>>> *Gesendet:* Dienstag, 4. November 2008 08:37
>>>>> *An:* mapbender_users at lists.osgeo.org
>>>>> *Betreff:* AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>>>>> Hello Mr. Schönhammer,
>>>>> I still have the same problems in a system combination
>>>> with Ubuntu
>>>>> 8.04 (Server) and the IE6 (Client). With FF or IE7 I don't have
>>>>> any Problems. In a system combination Debian
>> Etch/Lenny (Server)
>>>>> and any Browser I don't have any problems with
>> save/load WMC too.
>>>>> Perhaps you can try another combination to test the behavior of
>>>>> the module mod_savewmc.php. Unfortunately I don't know
>> a solution
>>>>> for the first combination.
>>>>> Greetings
>>>>> Burghardt Scholle
>>>>> [mailto:mapbender_users-bounces at lists.osgeo.org]*Im Auftrag
>>>>> von *Schönhammer, Herbert
>>>>> *Gesendet:* Dienstag, 4. November 2008 08:16
>>>>> *Betreff:* [Mapbender-users] MB 2.5: Error in
>>>> saveWMC / loadWMC
>>>>> Hi list,
>>>>> I want to generate a WMC-Document with MB 2.5 using
>>>> the module
>>>>> mod_savewmc.php.
>>>>> Clicking the button "Save workspace as Web Map Context
>>>>> Document" I am asked for the name of the workspace.
>>>>> And that was all.
>>>>> The wmc-document ist not offered using module
>>>> mod_loadwmc.php.
>>>>> MapBender does not create an entry in mb_error_logs.
>>>>> I don't find any record in the table mb_user_wmc
>> or any file
>>>>> on the server or an my client.
>>>>> I have tried all combinations with the var saveInSession:
>>>>> - the var was set / unset
>>>>> - the var was filled with the values 0/1
>>>>> - the var was filled with the values true/false
>>>>> The behaviour is reproducable with the shipped guis
>>>> gui1 and gui2.
>>>>> Where is the problem ?
>>>>> Has anybody a solution for me ?
>>>>> Greetings
>>>>> Schönhammer Herbert
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>> Where2B-Konferenz
>>>> Die Geo-IT Konferenz der WhereGroup
>>>> vom 9.-10. Dezember 2008 in Bonn
>>>> Web: www.where2b-conference.com
>>>> W h e r e G r o u p GmbH & Co. KG
>>>> Siemensstraße 8
>>>> 53121 Bonn
>>>> Germany
>>>> Christoph Baudson
>>>> Anwendungsentwickler
>>>> Fon: +49 (0)228 / 90 90 38 - 15
>>>> Fax: +49 (0)228 / 90 90 38 - 11
>>>> christoph.baudson at wheregroup.com
>>>> www.wheregroup.com
>>>> Amtsgericht Bonn, HRA 6788
>>>> Komplementärin:
>>>> WhereGroup Verwaltungs GmbH
>>>> vertreten durch:
>>>> Olaf Knopp, Peter Stamm
>> Where2B-Konferenz
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> www.wheregroup.com
>> Komplementärin:
>> vertreten durch:
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkkQR2AACgkQRTmqCdK7E6r8EgCg3O445iDWmrQsPPTSp+7XuBBm
g3UAn3sXbHPAUR13FTXeqd5blv2fZhY3
=upK7
-----END PGP SIGNATURE-----
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20081104/57d2676b/marco_lechner-0001.vcf
More information about the Mapbender_users
