AW: [Mapbender-users] bug fix / GUIDE HOW TO APPLY BUG FIXES
Schönhammer, Herbert
Schoenhammer.Herbert at Regensburg.de
Mon Nov 10 07:56:51 EST 2008
Thanks,
I have downloaded the complete modul. The umlauts are restored correct now !
thanks very much
Schoenhammer Herbert
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Christoph Baudson
>Gesendet: Montag, 10. November 2008 10:08
>An: Mapbender User List
>Betreff: [Mapbender-users] bug fix / GUIDE HOW TO APPLY BUG FIXES
>Christoph Baudson schrieb:
>> Thanks for your detailled suggestions. I will look into the load WMC
>> issue concerning character encoding.
>You were right about this. I filed the following ticket
>http://trac.osgeo.org/mapbender/ticket/321
>Here's how to install the bug fix: The last entry in this ticket links
>to the changeset
>http://trac.osgeo.org/mapbender/changeset/3207/
>which contains the bits of code I changed in order to make it work. The
>changeset contains the patch. Every closed ticket should have a link to
>a changeset (If the closed ticket does not contain a link to a
>changeset, ask the person who closed the ticket).
>If you encounter a patch in a changeset
>1) Don't panic
>2) Click on the link in order to get to the changeset
>3) Check "Files" (these files have been changed). Follow the link, in
>this case
>http://trac.osgeo.org/mapbender/browser/branches/2.5/http/class
>es/class_wmc.php?rev=3207
>Notice the revision number, 3207. This is the exact version of the file
>containing the bug fix. Don't download the most recent
>version, download
>this exact version just to make sure.
>4) Scroll down, and you will see a link "Original format". This is the
>link to the changed file. Download it and replace your old version with
>this new one (consider backing up your old file)
>(Another way of applying the patch would be to click "Unified diff" on
>the changeset page...but I guess you would have to manually rename the
>paths in the diff...so this might be an advanced solution, but
>inevitable for patches where a lot of files have changed)
>If the bug fix doesn't work, please feel free to re-open the
>ticket. You
>need an account to do this. See
>http://www.mapbender.org/Trac#Register
>for details.
>Any questions? Please feel free to ask. I'm happy to explain
>Trac in detail.
>Christoph
>> FYI: The WMC component of Mapbender has already been overhauled for
>> the upcoming Mapbender 2.6. Most likely, little to no bug fixing will
>> be done in this field in the 2.5 series. Please feel free to download
>> Mapbender directly from the SVN repository at
>> http://svn.osgeo.org/mapbender/trunk/mapbender/
>> in order to test the latest development. Remember to additionally
>> execute the update_2.6.sql file.
>> Mapbender 2.6 will not include as many new features and grave changes
>> as 2.5 did, so it will not be delayed this time. RC1 is scheduled for
>> early January 2009, a stable release for FOSSGIS 2009.
>> Have a nice weekend
>> Christoph Baudson
>> Burghardt.Scholle at stadt.wolfsburg.de schrieb:
>>> Hello list,
>>> I can confirm the errors, Mr. Schönhammer describe very clearly.
>>> Particularly the points 2 and 3 are very important for us too. Many
>>> of our users save their "projects" in a WMC-Document and would like
>>> to have german umlauts after reloading. We use our city map as
>>> overview too - it's very practical for orientation. Until mapbender
>>> version 2.2.3 the overview always was generated - no matter whether
>>> its WMS was switched on or off. I know that the associated procedur
>>> was redesigned, but the actual behavior is "suboptimal". I would
>>> appreciate a better solution too.
>>> Greetings
>>> Burghardt Scholle
>>> [mailto:mapbender_users-bounces at lists.osgeo.org]Im Auftrag von
>>> Gesendet: Donnerstag, 6. November 2008 17:32
>>> An: mapbender_users at lists.osgeo.org
>>> Betreff: [Mapbender-users] MB 2.5: Erros in modules loadwmc
>/ overview
>>> Hi list,
>>> now I'm doing the second sight for loadwmc. I think, i have found
>>> some erros and I have some questions too:
>>> 1. Error: Positioning of Overview
>>> Like in earlier versions of MB 2.5, the overview-picture is
>>> positioned wrong in the overview after loading a wmc. The picture in
>>> the overview is smaller than the picture in the original gui.
>>> 2. Error: German Umlauts in WMS- and Layer-Title
>>> Yes I know, we should avoid them, but we all must "sell" our work to
>>> our chiefs too ;-)
>>> Using german umlauts in a mapserver mapfile and loading this wms in
>>> mapbpender, the umlauts are displayed correctly. Saving a wmc, (I
>>> think) the umlauts are stored correct too.
>>> But after loading the wmc, the umlauts are not displayed correct.
>>> 3. Problem/Error: Which content in Overview ?
>>> In a "normal" gui, the overview picture is generated by a wms. The
>>> number of the used wms ist stored in attribute SRC of module
>>> overview: ../php/mod_mapOV.php?wms=3&....
>>> Therefore the wms must be loaded into the gui AND the wms must be
>>> VISIBLE (if the wms is "hidden", no overview picture is displayed in
>>> mapbender; this is a different behavior by comparison to earlier
>>> MapBender-versions !).
>>> Let's assume, we use wms "Stadtplan" (WMS id = 3) as wms for
>>> generating the overview picture.
>>> Let's assume, the user don't want to see the wms "Stadtplan" (the
>>> user switches off the checkbox for this wms; this is possible,
>>> because the wms must be visible !). The user chooses other wms.
>>> Now the user saves a wmc and loads this wmc.
>>> After loading the wmc no overview picture is generated. The needed
>>> wms is not checked !
>>> 3. Suggestions for solution
>>> 3.1 Overview with static pixmap (my priority ONE)
>>> Mapbender should offer another, second possibility for generating
>>> overviews. A pixmap should be used (the limits and epsg-code may be
>>> given as a var for module overview).
>>> This pixmap will always be used, independent from user's
>choice of wms.
>>> Another benefit is, that the server has no not to compute wms
>>> requests for overviews.
>>> 3.2 The "old" MapBender behavior ist restored (my priority TWO)
>>> If a "hidden" wms could be used (again) for generating overviews, a
>>> "hidden" wms with id=0 could ALWAYS be loaded into a gui. So always
>>> the same overview is used in a gui, independent of the selected wms.
>>> 3.3 Mapbender Extensions in WMC-XML-file (my priority THREE)
>>> MabBender will also save the WMS for generating the overview picture
>>> as a mapbender extension in the wmc file.
>>> Is there a possibility to implement solutions 3.1 and/or 3.2 at once
>>> ? Or in the next MB version 2.5.1 ?
>>> Or has anybody a tipp for me, how to restore the old mapbender
>>> behavior ?
>>> greetings
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>Where2B-Konferenz
>Die Geo-IT Konferenz der WhereGroup
>vom 9.-10. Dezember 2008 in Bonn
>Web: www.where2b-conference.com
>W h e r e G r o u p GmbH & Co. KG
>Siemensstraße 8
>53121 Bonn
>Germany
>Christoph Baudson
>Anwendungsentwickler
>Fon: +49 (0)228 / 90 90 38 - 15
>Fax: +49 (0)228 / 90 90 38 - 11
>christoph.baudson at wheregroup.com
>www.wheregroup.com
>Amtsgericht Bonn, HRA 6788
>Komplementärin:
>WhereGroup Verwaltungs GmbH
>vertreten durch:
>Olaf Knopp, Peter Stamm
More information about the Mapbender_users
