[Mapbender-users] how much time for pdf creation ???
    Michael Schulz
    mschulz at webgis.de
    Mon Oct  6 09:34:30 EDT 2008
"usually" depends at most on the desired quality of the print, meaning
either 72 or 288 dpi ...
The slowest part of the pdf generation are the getmap requests and
waiting for the response images. A reasonible WMS should be able to
produce a 72 dpi A4 image in several seconds, so depending on how many
wms are included in the pdf, a total time of one minute seems pretty
long (but not necessarily impossible).
If you have problems with not finished pdf generation (white page
after starting the print) I'd recommend an increased memory_limit
value (e.g 64M) in your php.ini.
HTH, Michael
2008/10/6 vollbotz <volker.emmel at lwk-rlp.de>:
> hi,
> i just want to know how long mapbender "usually" needs for the production of
> a pdf.
> i use mapbender_2.5 and the ubuntu_vm from http://www.gisvm.com/
>> i use the apache compression but have done no changes on the ubuntu
>> system...
> only on php.ini:
> max_execution_time = 60     ; Maximum execution time of each script, in
> seconds
> max_input_time = 120 ; Maximum amount of time each script may spend parsing
> request data
> ;max_input_nesting_level = 64 ; Maximum input variable nesting level
> memory_limit = 16M      ; Maximum amount of memory a script may consume
> (16MB)
> right now - i need for a din a4 page about one minute...
> is this usually ??
> what can i do ??
> thanks
> View this message in context: http://www.nabble.com/how-much-time-for-pdf-creation-----tp19837702p19837702.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Besuchen Sie uns auf der Intergeo in Bremen
30.09. - 02.10.2008 - Open Source Park, Halle 5, Stand 5.128
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
