[Mapbender-users] Query Parameter for a specific external WMS
Michael Schulz
mschulz at webgis.de
Thu Oct 30 11:04:32 EDT 2008
Hi Gisbert,
are you using firefox? If yes, then right click somewhere in the
mapbender GUI -> SeitenInformationen anzeigen -> Medien
Scroll to and click the line that should be your map request, copy the
whole url from the field Adresse (triple click). Either post it here
or compare it to the url that you received, especially look for the
time parameter you want to add as a vsp.
Cheers, Michael
2008/10/30 <gisbert.breitbach at gkss.de>:
> Hi Michael,
> I got no Mapbender error log.
> I want to use the time parameter for an external WMS server from UK. They
> gave me an URL like that:
> http://www.npm.ac.uk/rsg/projects/interrisk/ncof_mapserver_wms?map=/var/
> www/cgi-bin/wms.map&FORMAT=image%2Fpng&TRANSPARENT=true&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&EXCEPTIONS=XML&LAYERS=zg_MYO_chlor_a_time&SERVICE=MS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A4326&BBOX=-11.25,56.25,0,67.5&WIDTH=256&HEIGHT=256
> This URL works for a browser. I removed all other WMS from the GUI. Just
> this WMS and demis.nl stay as part of the GUI. I put this WMS on the first
> position and removed the setBackground stuff. But the result is no map and
> even no frame.
> I'm a little bit helpless, Gisbert
> ____________________________________________________
> Gisbert Breitbach, GKSS Forschungszentrum
> Tel.: +49 4152 87 1563
> Fax: +49 4152 87 4 1563
> E-Mail: Gisbert.Breitbach at gkss.de
> mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 15:31:45:
>> Hi Gisbert,
>> your function looks ok. Is your WMS setup to respond accordingly? Did
>> you check the mapbender and / or mapserver log?
>> If you are using umn: I don't know what mapserver does, when a getmap
>> with time parameter request comes in but the requested layer has no
>> time metadata setup. I think mapserver tries to create a corresponding
>> time expression, but as no time column was defined probably fails.
>> Could that be the case?
>> Have you looked at that document:
>> http://mapserver.gis.umn.edu/docs/howto/wms_time_support ?
>> Cheers, Michael
>> > Hi,
>> > but how do I add the time parameter as a vendor specific parameter.
>> > I tried to use mod_add_vendorspecific.php
>> > with that kind of code:
>> > <?php
>> > # $Id:
>> > # add vendor-specific parameters to MapRequest and FeatureInfoRequests
>> > # http://www.mapbender.org/index.php/mod_add_vendorspecific.php
>> > # Copyright (C) 2002 CCGIS
>> > # This program is free software; you can redistribute it and/or modify
>> > # it under the terms of the GNU General Public License as published by
>> > # the Free Software Foundation; either version 2, or (at your option)
>> > # any later version.
>> > # This program is distributed in the hope that it will be useful,
>> > # but WITHOUT ANY WARRANTY; without even the implied warranty of
>> > # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
>> > # GNU General Public License for more details.
>> > # You should have received a copy of the GNU General Public License
>> > # along with this program; if not, write to the Free Software
>> > # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
> 02111-1307,
>> > USA.
>> > require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
>> > mb_registerVendorSpecific("mod_vs_init()");
>> > function mod_vs_init(){
>> > var re = "time=<?php echo
>> > "2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00" ?>";
>> > return re;
>> > The only thing that happened is that all maps disappeared including
>> > background, overview and mapframe.
>> > Best regards,
>> > Gisbert
>> > mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 14:33:57:
>> >> Hi,
>> >> I don't think this is possible at the moment. Mapbender is not aware
>> >> of the wms time component. What you could do, is to add the time
>> >> parameter as a vendor specific parameter, that would be controlled by
>> >> a customized module.
>> >> If you want to use the wms time parameter you would also have to
> setup
>> >> your wms accordingly, so that you only have one layer "chlorophyll
>> >> measurements" and a time column for your data.
>> >> Cheers, Michael
>> >> > Hello everybody,
>> >> > I'm using Mapbender to show different measured raster maps, for
>> > example
>> >> > Chlorophyll in the north sea measured by satellites. Every day a
> new
>> >> > measurement is done. In my own WMS every new measurement means a
> new
>> > layer
>> >> > with a name reflecting the date.
>> >> > Other people have solved the problem introducing a time filter
>> > parameter
>> >> > into the GetMap request like
>> >> > ...&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&...
>> >> > Is it possible to include such a filter parameter into the GetMap
>> > request
>> >> > of Mapbender and, if yes, how can it be done.
>> >> > Many thanks,
>> >> > Gisbert Breitbach
>> >> > Mapbender_users mailing list
>> >> > Mapbender_users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> >> Michael Schulz
>> >> in medias res
>> >> Gesellschaft für Informationstechnologie mbH
>> >> In den Weihermatten 66
>> >> 79108 Freiburg
>> >> Tel +49 (0)761 556959-5
>> >> Fax +49 (0)761 556959-6
>> >> http://www.webgis.de / http://www.zopecms.de
>> >> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>> >> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>> Michael Schulz
>> in medias res
>> 79108 Freiburg
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_users
