[Mapbender-users] Query Parameter for a specific external WMS
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Thu Oct 30 11:45:09 EDT 2008
Hello,
is it possible to take a look at your mapbender installation? If it's
not possible please separate the maprequests in Firefox (page info ->
media) and post them to this list.
Maybe they are a little bit enlightening.
regards
Uli
gisbert.breitbach at gkss.de schrieb:
> Hi Michael,
> I got no Mapbender error log.
> I want to use the time parameter for an external WMS server from UK. They
> gave me an URL like that:
> http://www.npm.ac.uk/rsg/projects/interrisk/ncof_mapserver_wms?map=/var/
> www/cgi-bin/wms.map&FORMAT=image%2Fpng&TRANSPARENT=true&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&EXCEPTIONS=XML&LAYERS=zg_MYO_chlor_a_time&SERVICE=MS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A4326&BBOX=-11.25,56.25,0,67.5&WIDTH=256&HEIGHT=256
> This URL works for a browser. I removed all other WMS from the GUI. Just
> this WMS and demis.nl stay as part of the GUI. I put this WMS on the first
> position and removed the setBackground stuff. But the result is no map and
> even no frame.
> I'm a little bit helpless, Gisbert
> ____________________________________________________
> Gisbert Breitbach, GKSS Forschungszentrum
> Tel.: +49 4152 87 1563
> Fax: +49 4152 87 4 1563
> E-Mail: Gisbert.Breitbach at gkss.de
> mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 15:31:45:
>> Hi Gisbert,
>> your function looks ok. Is your WMS setup to respond accordingly? Did
>> you check the mapbender and / or mapserver log?
>> If you are using umn: I don't know what mapserver does, when a getmap
>> with time parameter request comes in but the requested layer has no
>> time metadata setup. I think mapserver tries to create a corresponding
>> time expression, but as no time column was defined probably fails.
>> Could that be the case?
>> Have you looked at that document:
>> http://mapserver.gis.umn.edu/docs/howto/wms_time_support ?
>> Cheers, Michael
>> 2008/10/30 <gisbert.breitbach at gkss.de>:
>>> Hi,
>>> but how do I add the time parameter as a vendor specific parameter.
>>> I tried to use mod_add_vendorspecific.php
>>> with that kind of code:
>>> <?php
>>> # $Id:
>>> # add vendor-specific parameters to MapRequest and FeatureInfoRequests
>>> # http://www.mapbender.org/index.php/mod_add_vendorspecific.php
>>> # Copyright (C) 2002 CCGIS
>>> # This program is free software; you can redistribute it and/or modify
>>> # it under the terms of the GNU General Public License as published by
>>> # the Free Software Foundation; either version 2, or (at your option)
>>> # any later version.
>>> # This program is distributed in the hope that it will be useful,
>>> # but WITHOUT ANY WARRANTY; without even the implied warranty of
>>> # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
>>> # GNU General Public License for more details.
>>> # You should have received a copy of the GNU General Public License
>>> # along with this program; if not, write to the Free Software
>>> # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
> 02111-1307,
>>> USA.
>>> require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
>>> mb_registerVendorSpecific("mod_vs_init()");
>>> function mod_vs_init(){
>>> var re = "time=<?php echo
>>> "2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00" ?>";
>>> return re;
>>> The only thing that happened is that all maps disappeared including
>>> background, overview and mapframe.
>>> Best regards,
>>> Gisbert
>>> mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 14:33:57:
>>>> Hi,
>>>> I don't think this is possible at the moment. Mapbender is not aware
>>>> of the wms time component. What you could do, is to add the time
>>>> parameter as a vendor specific parameter, that would be controlled by
>>>> a customized module.
>>>> If you want to use the wms time parameter you would also have to
> setup
>>>> your wms accordingly, so that you only have one layer "chlorophyll
>>>> measurements" and a time column for your data.
>>>> Cheers, Michael
>>>>> Hello everybody,
>>>>> I'm using Mapbender to show different measured raster maps, for
>>> example
>>>>> Chlorophyll in the north sea measured by satellites. Every day a
> new
>>>>> measurement is done. In my own WMS every new measurement means a
> new
>>> layer
>>>>> with a name reflecting the date.
>>>>> Other people have solved the problem introducing a time filter
>>> parameter
>>>>> into the GetMap request like
>>>>> ...&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&...
>>>>> Is it possible to include such a filter parameter into the GetMap
>>> request
>>>>> of Mapbender and, if yes, how can it be done.
>>>>> Many thanks,
>>>>> Gisbert Breitbach
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>> Michael Schulz
>>>> mschulz at webgis.de
>>>> in medias res
>>>> Gesellschaft für Informationstechnologie mbH
>>>> In den Weihermatten 66
>>>> 79108 Freiburg
>>>> Tel +49 (0)761 556959-5
>>>> Fax +49 (0)761 556959-6
>>>> http://www.webgis.de / http://www.zopecms.de
>>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>> Michael Schulz
>> in medias res
>> 79108 Freiburg
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
