[Mapbender-users] [Mapbender] #455: Dynamic print frame
mapbender_dev at lists.osgeo.org
Mon Apr 27 04:48:25 EDT 2009
Reporter: christoph | Owner: user
Type: feature request | Status: new
Priority: major | Milestone: 2.7 release
Component: print | Version:
Keywords: |
The printable extent should be displayed in the map as an individual frame
(currently, the map size is adjusted to represent the print size).
The print frame shall have the following properties
* movable via drag and drop
* rotatable via mouse and form element (angle)
* resizable via mouse and form element (scale)
'''A prototype has been created. A demo will follow shortly.'''
Open issues
* rotated north arrow
* rotated map extent has to be highlighted in overview in PDF
* scale in PDF is not correct (scale of map is used, not of frame)
* php5-imagick installation on demo server
* sandclock during PDF generation
* button for print frame if print dialogue is in iframe (not in popup)
* transparency display in IE
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/455>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_users
