[Mapbender-users] Upload WMS fails with no Error
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Fri Dec 11 02:44:45 EST 2009
Hello Friedrich,
you should set
define("NOT_PROXY_HOSTS", "127.0.0.1,localhost"); # and whatever ip or name
which is not reachable thru your defined proxy.
Don't forget to to set your proxy connection and have a look at
http://trac.osgeo.org/mapbender/changeset/5013
Regards
Armin
Am Mittwoch 09 Dezember 2009 21:11:58 schrieb Friedrich Hoedl:
> Dear Michael,
> Yes, Mapbender and Mapserver are running on the same Machine.
> The installed Mapbender Version is 2.6 on Windows 2008 OS.
> Your idea was great. Indeed it is a connection problem:
> I separated Mapbender and Mapserver and moved Mapserver into a Virtual
> Machine.
> I tried to upload the WMS again and now it goes!
> OK, so far so good - which setup do i need, to run both applications on one
> system:
> Is it sufficient to configure in Mapbender.conf:
> define("CONNECTION", "curl");
> define("NOT_PROXY_HOSTS", "127.0.0.1");
> ... or do I need something else?
> Unfortunately when using these settings and retried to upload a WMS, the
> same error occurs in the Mapbender GUI.
> The Mapbender-Log-Entries are not very meaningful :
> 2009.12.09, 20:59:07,Notice: class_locale: setting locale to en
> 2009.12.09, 20:59:07,Notice: locale English_United States.1252 ok on
> windows 2009.12.09, 20:59:07,Notice: mb_validateSession.php: checking file
> /mapbender/php/mod_loadwms.php
> 2009.12.09, 20:59:07,Notice: gui id not set
> 2009.12.09, 20:59:07,Notice: gui id set to guiID: admin2_de
> 2009.12.09, 20:59:07,Notice: mb_validateSession.php: GUI: admin2_de,
> checking file /mapbender/php/mod_loadwms.php...session valid.
> 2009.12.09, 20:59:07,Notice: administration->getGuisByPermission is
> deprecated, use user->getApplicationsByPermission instead!
> 2009.12.09, 20:59:07,Notice: mb_validatePermission.php: checking file
> /mapbender/php/mod_loadwms.php...permission valid.
> 2009.12.09, 20:59:07,Notice: CURL host:localhost
> Thanks again and best regards
> Fritz Hoedl
> > -----Original Message-----
> > From: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-
> > bounces at lists.osgeo.org] On Behalf Of Michael Schulz
> > Sent: Wednesday, December 09, 2009 7:32 PM
> > To: Mapbender User List
> > Subject: Re: [Mapbender-users] Upload WMS fails with no Error
> > Hi,
> > what Mapbender version are you using? It sounds like a http connection
> > problem. I assume Mapbender is also running on localhost?
> > Have you configured a proxy? In recent mapbender version you can
> > define no_proxy locations, when using connection type curl.
> > Have a look a the logfile. Usually connection problems should show up
> > there.
> > Cheers, Michael
> > 2009/12/9 Friedrich Hoedl <friedrich.hoedl at hoedl-online.de>:
> > > Dear Mapbender Community,
> > > now i have been searching for a long time in this mailinglist to fix
> > my
> > > phenomenon but until now I had no success.
> > > So i´d like to place my question right here in this mailinglist:
> > > I still have a fully functional mapserver-Installation with a mapfile
> > that
> > > is based on an example taken out of one of the O´Reilly-Books
> > > (http://www.webmappingillustrated.com/Beispiele ) and liked to
> > publish a WMS
> > > with one Layer.
> > > Therefore I tried to upload this new WMS to my existing windows
> > mapbender
> > > Installation.
> > > I don´t have a problem to load this WMS under Quantum GIS and in
> > there, my
> > > layer is shown correctly.
> > > So I went back to mapbender and tried to load the same WMS by
> > clicking Load
> > > WMS in the Main Menue.
> > > I used the following URL:
> > > http://localhost/cgi-
> > bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/global.map&RE
> > > QUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
and pushed the Load - Button.
> > > After some time (approx. 30 Seconds) the Browser gave back the URL:
> > > file:
> > > but nothing else.
> > > The Logfiles (Apache, PHP and mapbender) doesn´t show anything
> > unusual.
> > > Does anyone knows what this means?
> > > I don´t know what´s not ok the mapfile?
> > > Something in my mapbender-configuration?
> > > Opening an external WMS works fine so i´m very confused where to
> > search
> > > next.
> > > Thanks for all and best regards
> > > Fritz Hoedl
> > > _______________________________________________
> > > Mapbender_users mailing list
> > > Mapbender_users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Aufwind durch Wissen!
> > Qualifizierte Open Source Schulungen bei der
> > http://www.foss-akademie.de/
> > Michael Schulz
> > mschulz at webgis.de
> > in medias res
> > Gesellschaft für Informationstechnologie mbH
> > +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
> > Schwimmbadstraße 2
> > D-79100 Freiburg i. Br.
> > Tel: +49 (0)761 705798-102
> > Tel: +49 (0)761 705798-0
> > Fax: +49 (0)761 705798-09
> > http://www.webgis.de / http://www.zopecms.de
> > Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> > Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users
