[Mapbender-users] Upload WMS fails with no Error
Friedrich Hoedl
friedrich.hoedl at hoedl-online.de
Fri Dec 11 17:01:53 EST 2009
Dear Astrid, dear Armin,
now it works!
I set
define("CONNECTION", "curl");
define("NOT_PROXY_HOSTS", "<MyIP>")
where <MyIP> is 192.168.50.52
Before that, i tried it with "localhost" and "127.0.0.1" but that didn´t
work either.
Again, thanks for your help and have a nice time
Fritz Hoedl
> -----Original Message-----
> From: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-
> bounces at lists.osgeo.org] On Behalf Of Armin Retterath
> Sent: Friday, December 11, 2009 8:45 AM
> To: mapbender_users at lists.osgeo.org
> Subject: Re: [Mapbender-users] Upload WMS fails with no Error
> Hello Friedrich,
> you should set
> define("NOT_PROXY_HOSTS", "127.0.0.1,localhost"); # and whatever ip or
> name
> which is not reachable thru your defined proxy.
> Don't forget to to set your proxy connection and have a look at
> http://trac.osgeo.org/mapbender/changeset/5013
> Regards
> Armin
> Am Mittwoch 09 Dezember 2009 21:11:58 schrieb Friedrich Hoedl:
> > Dear Michael,
> > Yes, Mapbender and Mapserver are running on the same Machine.
> > The installed Mapbender Version is 2.6 on Windows 2008 OS.
> > Your idea was great. Indeed it is a connection problem:
> > I separated Mapbender and Mapserver and moved Mapserver into a
> Virtual
> > Machine.
> > I tried to upload the WMS again and now it goes!
> > OK, so far so good - which setup do i need, to run both applications
> on one
> > system:
> > Is it sufficient to configure in Mapbender.conf:
> > define("NOT_PROXY_HOSTS", "127.0.0.1");
> > ... or do I need something else?
> > Unfortunately when using these settings and retried to upload a WMS,
> the
> > same error occurs in the Mapbender GUI.
> > The Mapbender-Log-Entries are not very meaningful :
> > 2009.12.09, 20:59:07,Notice: class_locale: setting locale to en
> > 2009.12.09, 20:59:07,Notice: locale English_United States.1252 ok on
> > windows 2009.12.09, 20:59:07,Notice: mb_validateSession.php: checking
> file
> > /mapbender/php/mod_loadwms.php
> > 2009.12.09, 20:59:07,Notice: gui id not set
> > 2009.12.09, 20:59:07,Notice: gui id set to guiID: admin2_de
> > 2009.12.09, 20:59:07,Notice: mb_validateSession.php: GUI: admin2_de,
> > checking file /mapbender/php/mod_loadwms.php...session valid.
> > 2009.12.09, 20:59:07,Notice: administration->getGuisByPermission is
> > deprecated, use user->getApplicationsByPermission instead!
> > 2009.12.09, 20:59:07,Notice: mb_validatePermission.php: checking file
> > /mapbender/php/mod_loadwms.php...permission valid.
> > 2009.12.09, 20:59:07,Notice: CURL host:localhost
> > Thanks again and best regards
> > Fritz Hoedl
> > > bounces at lists.osgeo.org] On Behalf Of Michael Schulz
> > > Sent: Wednesday, December 09, 2009 7:32 PM
> > > To: Mapbender User List
> > > Hi,
> > > what Mapbender version are you using? It sounds like a http
> connection
> > > problem. I assume Mapbender is also running on localhost?
> > > Have you configured a proxy? In recent mapbender version you can
> > > define no_proxy locations, when using connection type curl.
> > > Have a look a the logfile. Usually connection problems should show
> up
> > > there.
> > > Cheers, Michael
> > > 2009/12/9 Friedrich Hoedl <friedrich.hoedl at hoedl-online.de>:
> > > > Dear Mapbender Community,
> > > > now i have been searching for a long time in this mailinglist to
> fix
> > > my
> > > > phenomenon but until now I had no success.
> > > > So i´d like to place my question right here in this mailinglist:
> > > > I still have a fully functional mapserver-Installation with a
> mapfile
> > > that
> > > > is based on an example taken out of one of the O´Reilly-Books
> > > > (http://www.webmappingillustrated.com/Beispiele ) and liked to
> > > publish a WMS
> > > > with one Layer.
> > > > Therefore I tried to upload this new WMS to my existing windows
> > > mapbender
> > > > Installation.
> > > > I don´t have a problem to load this WMS under Quantum GIS and in
> > > there, my
> > > > layer is shown correctly.
> > > > So I went back to mapbender and tried to load the same WMS by
> > > clicking Load
> > > > WMS in the Main Menue.
> > > > I used the following URL:
> > > > http://localhost/cgi-
> > > bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/global.map&RE
> > > > QUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
and pushed the Load - Button.
> > > > After some time (approx. 30 Seconds) the Browser gave back the
> URL:
> > > > file:
> > > > but nothing else.
> > > > The Logfiles (Apache, PHP and mapbender) doesn´t show anything
> > > unusual.
> > > > Does anyone knows what this means?
> > > > I don´t know what´s not ok the mapfile?
> > > > Something in my mapbender-configuration?
> > > > Opening an external WMS works fine so i´m very confused where to
> > > search
> > > > next.
> > > > Thanks for all and best regards
> > > > Fritz Hoedl
> > > > _______________________________________________
> > > > Mapbender_users mailing list
> > > > Mapbender_users at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > > Aufwind durch Wissen!
> > > Qualifizierte Open Source Schulungen bei der
> > > http://www.foss-akademie.de/
> > > Michael Schulz
> > > mschulz at webgis.de
> > > in medias res
> > > Gesellschaft für Informationstechnologie mbH
> > > +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
> > > Schwimmbadstraße 2
> > > D-79100 Freiburg i. Br.
> > > Tel: +49 (0)761 705798-102
> > > Tel: +49 (0)761 705798-0
> > > Fax: +49 (0)761 705798-09
> > > http://www.webgis.de / http://www.zopecms.de
> > > Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> > > Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
> Im Auftrag
> Armin Retterath
> Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
> beim
> Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
> Ferdinand-Sauerbruch-Straße 15
> 56073 Koblenz
> Telefon 0261/492-466
> Telefax 0261/492-492
> armin.retterath at lvermgeo.rlp.de
> http://www.geoportal.rlp.de
More information about the Mapbender_users
