[Mapbender-users] map and other GUI elements disappear
Christoph Baudson
christoph.baudson at wheregroup.com
Mon Feb 9 04:39:57 EST 2009
Balázs Bámer schrieb:
> Hi Christoph,
>> which elements did you switch off?
> I will respond in more detail. Now just a quick question: meanwhile I
> installed 2.4.5 as well, and it works much better, altough I have
> problems there, too. Which one would you recommend regarding
> stability, reliability?
The 2.4.x misses a lot of bug fixes that have been included in 2.5, see
http://trac.osgeo.org/mapbender/query?status=closed&milestone=2.5+release&order=type
So far, we have received mostly positive feedback for 2.5. It is in wide
use and as far as I'm concerned has proven to be stable. However, bugs
are a reality. With everyone's help we can limit them to a reasonable
amount.
Therefore I would recommend 2.5.
> I couldn't see any function in 2.5 I would miss in 2.4.5
> thank you in advance, best regards: Balázs
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
