[Mapbender-users] No Frames after login
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Feb 13 09:52:25 EST 2009
arista schrieb:
> Hi everyone,
> I installed Mapbender following the instructions. I can login using root /
> root. I also can change the root pwd and generate a new user.
> The issue is that I see no frames after login. All I can see is a table in
> this format:
Hi Marina,
did you enable JavaScript in your Browser?
What does mapbender_setup.php say?
Did you check the Mapbender log files?
Did you check the PHP log files?
Maybe create a new database and load the SQLs again to make sure the
installation worked. Maybe redirect possible SQL message to a log file.
Cheers
Christoph
> Mapbender GUI list Change personal settings [Logout button]
> GUI name GUI description
> admin1 admin GUI containing all adminstrative modules (use only as a
> template)
> admin2_de admin GUI in deutscher Sprache
> admin2_en admin GUI in english
> admin_de_services erweiterte admin GUI - WMS, WFS, Metadaten (deutsch)
> admin_en_services extended admin GUI - WMS, WFS, metadata-handling (english)
> gui GUI with tab, search modules
> gui1 GUI combining most of the Mapbender functionality
> gui2 GUI with focus on layout
> gui_digitize GUI with WFS search and digitizing using WFS-T
> wms_africa Container for Africa WMS
> wms_australia Container for Australia WMS
> wms_europe Container for european WMS
> wms_gdi_de Container for german WMS from GDI-DE
> wms_germany Container for german WMS
> wms_north_america Container for north America WMS
> wms_worldwide Container for world wide WMS
> When I try the links to "admin 1" for example, what I obtain is a blank
> page.
> I use php5.2.1 & mysql Ver 14.12 Distrib 5.0.38 for UBUNTU 7.04.
> Can you help, please?
> Thanks,
> Marina
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
