[Mapbender-users] No Frames after login
arista marina at geociencias.unam.mx
Fri Feb 13 17:55:04 EST 2009
Hi Christoph,
Hi Marina,
did you enable JavaScript in your Browser?
**I have the JaveScript enabled in the Browser (I use Firefox)
What does mapbender_setup.php say?
** the mapbander_setup.php says nothing about the DB (the DB panel is
empty), even if in the mapbender_setup.php I choose mysql as DB. Maybe this
is the problem.
Did you check the Mapbender log files?
Did you check the PHP log files?
Maybe create a new database and load the SQLs again to make sure the
installation worked. Maybe redirect possible SQL message to a log file.
**I will try to regenerate the DB
Cheers
Christoph
View this message in context: http://n2.nabble.com/No-Frames-after-login-tp2306604p2324290.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
