[Mapbender-users] WFS gazetteer problem
Christoph Baudson christoph.baudson at wheregroup.com
Fri Feb 13 10:23:49 EST 2009
Balázs Bámer schrieb:
> Hi All,
> I have Mapbender 5.2 on Ubuntu 8.10, WMS is Mapserver 5.2.1 which
> seems all right). My GUI is available here:
> http://att-it.homelinux.net:22080/mapbender/
> user: mapbenderlist, pass: =]-[0p
> I managed to set up WFS gazetteer, but it works in a strange way.
> First, I set its width to 800 pixels. You can try it:
> In the bottom left corner, select Csakolv
> In the merar field enter 1000
> After hitting the button below, 2 hits returned, but the lines are
> broken, altough 800 pixels should be enough.
Hi Balázs,
works for me in Firefox. Did you find what caused the problem?
> Moreover, result column
> labels are missing. I tried to define them like this:
> http://www.bamer.eu/wfs.png
I'm not sure if you can set labels for result sets. Maybe someone else
has to give a definitive answer. I *assume* Mapbender 2.6 will have
sortable result columns, I've heard rumours about it.
Christoph
> For the 2 big style fields which are cut off the png, I entered
> nothing, thinking that plain default styles are adequate for now.
> What is missing?
> my modules are:
> ajax
> back body
> center1 closePolygon copyright
> dependentDiv digitize dragMapSize
> featureInfo1 forward
> gazetteerWFS geometry getArea
> help
> legend logo logout
> mapframe1 measure metadata
> navFrame
> overview
> pan1 printPDF
> repaint rubber
> sandclock scalebar scaleSelect scaleText selArea1 setPOI2Scale
> setSpatialRequest showCoords_div showLoggedUser
> treeGDE
> wfs wfs_conf wfsresult
> zoomCoords zoomFull zoomIn1 zoomOut1
> thank you in advance.
> Best regards: Balázs Bámer
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
