[Mapbender-users] Problem with grouped layers and GetFeatureInfo
Marec
marec at t-online.de
Mon Feb 16 15:31:31 EST 2009
Hi Clemens,
you don't doing anything wrong.
As far as i know Mapbender doesn't support grouped queryLayers.
But there is a trick you can do it.
To solve your problem you have to connect to your Mapbender database via
phppgadmin or pgadmin3.
Open the table gui_layer and search your layer_id. (in your case its
fkey_layer_id = 20622).
Now you have to change the values of :
"gui_layer_queryable and gui_layer_querylayer"
from 0 to 1.
This should be activate your checkboxes and Mapbender will be request them.
regards Marc
beyer at multimediaplan.at schrieb:
> Hi group,
> I currently have a problem with grouped layers and GetFeatureInfo as
> follows:
> I have a mapfile with two layers which are combined in one group. Each of
> the two layers
> says that it can provide information (the info checkboxes are enabled),
> but the
> group layer says there is no info (checkboxes are disabled).
> (see screenshot: http://www.corp.at/temp/wms.jpg)
> All data is stored in a Postgres database. The two layers are grouped by
> the help of a UMN map file. When I set up a GetFeatureInfo request
> manually, it works -
> but Mapbender thinks my group layer does not have a featureInfo (error
> message: "Please
> select a layer! Bitte waehlen Sie eine Ebene zur Abfrage aus!").
> What am I doing wrong?
> Best regards,
> Clemens
> Und das Ganze auch auf Deutsch:
> Hallo Gruppe,
> ich habe momentan ein Problem mit grouped layers und GetFeatureInfo:
> Ich habe ein Mapfile mit zwei Layern, die in einer Gruppe zusammengefasst
> sind. Beide
> Layer haben offensichtlich abfragbare Zusatzinformation (die Checkboxen
> sind klickbar),
> aber der Gruppenlayer meint, da wäre nix (Checkboxen ausgegraut).
> (siehe Screenshot: http://www.corp.at/temp/wms.jpg)
> Alle Daten liegen in einer Postgres-Datenbank. Die beiden Layer sind im
> UMN-Mapfile
> gruppiert. Wenn ich einen GetFeatureInfo-Request händisch aufbaue,
> funktioniert er -
> aber Mapbender meint, mein Grupenlayer würde keine FeatureInfos haben
> (Fehlermeldung:
> "Please select a layer! Bitte waehlen Sie eine Ebene zur Abfrage aus!").
> Was mache ich da bloß falsch?
> LG,
> Clemens
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
