[Mapbender-users] Re: Mapbender recognizes wrong SRS of my
geoserver-WMS
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Fri Feb 27 11:25:08 EST 2009
Hello Albert,
you need postgis in your Mapbender database.
Please go to your Mapbender database and have a look whether you have
the tables geometry_column and spatial_ref_sys.
You also can check by the following sql :
select postgis_full_version(); in you Mapbender database.
If postgis is not install you can add it by three commands. Have a look at the postgis documentation.
Have a look at the link see 7. to 9.:
http://www.postgis.org/documentation/manual-1.3/ch02.html#PGInstall
Best regards Astrid
-------- Original-Nachricht --------
Betreff: Re: Mapbender recognizes wrong SRS of my geoserver-WMS
Datum: Thu, 26 Feb 2009 21:44:34 +0100
Von: Albrecht GMX <aweiser at gmx.de>
An: mapbender_users-request at lists.osgeo.org
<mapbender_users at lists.osgeo.org>
CC: astrid.emde at wheregroup.com
Referenzen: <20090226083506.312E0E01673 at lists.osgeo.org>
Hello Astrid,
indeed the mapbender setup checker showed an error in the postgis configuration:
Warning: pg_query() [function.pg-query]: Query failed: FEHLER: Funktion postgis_full_version() existiert nicht LINE 1: select postgis_full_version(); ^ HINT: Keine Funktion stimmt mit dem angegebenen Namen und den Argumenttypen überein. Sie müssen möglicherweise ausdrückliche Typumwandlungen hinzufügen. in D:\Server\clients\mapbender_2.4.5\http\tools\mapbender_setup.php on line 174
pg_query(Resource id #7,select postgis_full_version();)
PostGIS support no PostGIS function available
But my postgis is vital and working:
template_postgis=# \df postgis*
Liste der Funktionen
Schema | Name | Ergebnisdatentyp | Argumentdatenty
pen
public | postgis_full_version | text |
public | postgis_geos_version | text |
public | postgis_gist_joinsel | double precision | internal, oid, internal, smallint
public | postgis_gist_sel | double precision | internal, oid, internal, integer
public | postgis_jts_version | text |
public | postgis_lib_build_date | text |
public | postgis_lib_version | text |
public | postgis_proj_version | text |
public | postgis_scripts_build_date | text |
public | postgis_scripts_installed | text |
public | postgis_scripts_released | text |
public | postgis_uses_stats | boolean |
public | postgis_version | text |
(13 Zeilen)
template_postgis=# SELECT postgis_version();
postgis_version
1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
Also the database check of the setup checker shows all green lights. I didn't find the misconfiguration responsible for the postgis check errors :o(
Best regards
Albrecht
> Hello Albert,
> please check whether your Mapbender has PostGIS support (the Mapbender
> PostgreSQL database needs the postgis functions).
> For changing the EPSG we need the PostGIS function transform.
> Maybe this is the problem
> Best regards
> Astrid
> On Wed, February 25, 2009 12:27 pm, Albrecht Weiser wrote:
>> Hi mapbender list,
>> today i post a strange behaviour of my mapbender. I wanted to add a
>> geoserver WMS to my mapbender WMS-URL's. When creating a separate gui from
>> that, the initial SRS of the gui is epsg:4326. When i want to change to
>> the native SRS of the WMS (which is epsg:31467), the gui says "undefined".
>> But that's not true, because the only SRS defined in this WMS is
>> epsg:31467. That's a problem, because i want to overlay a WMS with a
>> topo-map from remote and thats in epsg:31467 too. If i want to load both
>> layers, i get an error: all layers must be in the same SRS.
>> But when i test the WMS with the test-mapbender from
>> http://mapbender.telascience.org, then the service is being correctly
>> bound as epsg:31467 (i can also switch to 4326 or 31466 even though these
>> SRS aren't defined in my WMS - weird thing!).
>> It means, my mapbender-settings are faulty somewhere.
>> Does somebody have an idea where to search?
>> Thanks
>> Albrecht
Mit freundlichen Grüßen
Astrid Emde
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
