[Mapbender-users] First steps on Mapbender...
Lluís Vicens
lluis at sigte.udg.es
Wed Jul 8 07:03:57 EDT 2009
Hi Michael,
So many thanks form your answer. I've been checking what you told me and
as an attachment you will find the mapbender/log file and below, there
is the result of executing the mapbender_setup.php
For your information, I am (trying) running mapbender 2.6 rc1 on Ubuntu
8.04.
Any thoughts?
Best regards,
Lluís
*Warning*:
require_once(/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php)
[function.require-once
<http://localhost/mapbender_2.6_rc1//tools/function.require-once>]:
failed to open stream: No such file or directory in
*/var/www/mapbender_2.6_rc1/tools/mapbender_setup.php* on line *24*
*Fatal error*: require_once() [function.require
<http://localhost/mapbender_2.6_rc1//tools/function.require>]: Failed
opening required
'/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php'
(include_path='.:/usr/share/php:/usr/share/pear') in
En/na Michael Schulz ha escrit:
> Hi Lluís,
> welcome on board :-)
> Could you have a look at the mapbender log file that is created in the
> /mapbender/log dir? Also it may be helpful to have a look at the
> output of mapbender_setup.php. Open this script in your browser and it
> will show a lot of information regarding mapbender/database
> surroundings. Also, a look in the apache/php error log may give some
> information.
> Please post any valuable information.
> Cheers, Michael
> 2009/7/7 Lluís Vicens <lluis at sigte.udg.es>:
>> Hi,
>> I'm totally newbie to Mapbender and, after completing the installation
>> process (now it seems that all it's ok) I proceed to login (root:root). No
>> errors showed but nothing is loaded :(
>> The only result is just an empty page (see attachment). What's wrong? Any
>> help?
>> Thanks in advance!
>> Lluís
>> map
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
2009.07.08, 12:31:39,ERROR: Error while preparing statement in /var/www/mapbender_2.6_rc1/http/frames/login.php: Sql: SELECT DISTINCT gui_id,gui_name,gui_description, ggc.*,gc.category_name,gc.category_description FROM gui g LEFT JOIN gui_gui_category ggc ON g.gui_id = ggc.fkey_gui_id LEFT JOIN gui_category gc ON (ggc.fkey_gui_category_id = gc.category_id) WHERE gui_id IN ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16) ORDER BY gc.category_name, gui_name, Error: ERROR: relation "gui_gui_category" does not exist
2009.07.08, 12:31:39,ERROR: Error while executing prepared statement in /var/www/mapbender_2.6_rc1/http/frames/login.php: Sql: SELECT DISTINCT gui_id,gui_name,gui_description, ggc.*,gc.category_name,gc.category_description FROM gui g LEFT JOIN gui_gui_category ggc ON g.gui_id = ggc.fkey_gui_id LEFT JOIN gui_category gc ON (ggc.fkey_gui_category_id = gc.category_id) WHERE gui_id IN ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16) ORDER BY gc.category_name, gui_name, Error: ERROR: unnamed prepared statement does not exist
More information about the Mapbender_users
