[Mapbender-users] First steps on Mapbender...
Astrid Emde
astrid.emde at wheregroup.com
Wed Jul 8 07:28:56 EDT 2009
Hello Llius,
I hope you took the Mapbender 2.6 from braches/2.6
You can donload it from http://trac.osgeo.org/mapbender/browser/branches/2.6
(We did a lot of bugfixxes since Mapbender 2.6rc1, so it makes sense to
take the package from /branches/2.6)
The error in the logfile says. ERROR: relation "gui_gui_category" does not
It seems that you don't have run the sql for the mapbender installation
properly (one table gui_gui_category is missing)
Please recreate your Database! You find an installation script at
mapbender/resources/db/install_2.6.sh (install_2.6.bat for windows)
which will lead you easily through the installation.
Then you just have to point the mapbender.conf to this new database.
If you still have problems let us know.
Astrid
Lluís Vicens schrieb:
> Hi Michael,
> So many thanks form your answer. I've been checking what you told me
> and as an attachment you will find the mapbender/log file and below,
> there is the result of executing the mapbender_setup.php
> For your information, I am (trying) running mapbender 2.6 rc1 on
> Ubuntu 8.04.
> Any thoughts?
> Best regards,
> Lluís
> *Warning*:
> require_once(/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php)
> [function.require-once
> <http://localhost/mapbender_2.6_rc1//tools/function.require-once>]:
> failed to open stream: No such file or directory in
> */var/www/mapbender_2.6_rc1/tools/mapbender_setup.php* on line *24*
> *Fatal error*: require_once() [function.require
> <http://localhost/mapbender_2.6_rc1//tools/function.require>]: Failed
> opening required
> '/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php'
> (include_path='.:/usr/share/php:/usr/share/pear') in
> En/na Michael Schulz ha escrit:
>> Hi Lluís,
>> welcome on board :-)
>> Could you have a look at the mapbender log file that is created in the
>> /mapbender/log dir? Also it may be helpful to have a look at the
>> output of mapbender_setup.php. Open this script in your browser and it
>> will show a lot of information regarding mapbender/database
>> surroundings. Also, a look in the apache/php error log may give some
>> information.
>> Please post any valuable information.
>> Cheers, Michael
>> 2009/7/7 Lluís Vicens <lluis at sigte.udg.es>:
>>> Hi,
>>> I'm totally newbie to Mapbender and, after completing the installation
>>> process (now it seems that all it's ok) I proceed to login
>>> (root:root). No
>>> errors showed but nothing is loaded :(
>>> The only result is just an empty page (see attachment). What's
>>> wrong? Any
>>> help?
>>> Thanks in advance!
>>> Lluís
>>> map
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
AGIT Konferenz 2009
8.-10. Juli 2009 in Salzburg
http://www.mapbender.org/Mapbender_on_Agit_2009
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
