[Mapbender-users] First steps on Mapbender...
Astrid Emde
astrid.emde at wheregroup.com
Wed Jul 8 12:03:03 EDT 2009
Hello Lluís,
there is another SQL update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql
You should run this aswell to correspond with the Mapbender 2.6 code.
have fun astrid
Lluís Vicens schrieb:
> Hi Astrid and Armin,
> It works! Thanks for your help. I've updated the mapbender database
> executing the correct sql (update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql) and
> then, I downloaded mapbender from branches 2.6 and I replaced the old
> folders and files for the new ones... I don't know if this is the
> best way to proceed but it works ;)
> Now, I'm starting to work on mapbender and take for sure that I will
> come back with tons of doubts :-[
> Regards,
> Lluís
> En/na Astrid Emde ha escrit:
>> Hello Llius,
>> I hope you took the Mapbender 2.6 from braches/2.6
>> You can donload it from
>> http://trac.osgeo.org/mapbender/browser/branches/2.6
>> (We did a lot of bugfixxes since Mapbender 2.6rc1, so it makes sense
>> to take the package from /branches/2.6)
>> The error in the logfile says. ERROR: relation "gui_gui_category"
>> does not
>> It seems that you don't have run the sql for the mapbender
>> installation properly (one table gui_gui_category is missing)
>> Please recreate your Database! You find an installation script at
>> mapbender/resources/db/install_2.6.sh (install_2.6.bat for windows)
>> which will lead you easily through the installation.
>> Then you just have to point the mapbender.conf to this new database.
>> If you still have problems let us know.
>> Astrid
>>> Hi Michael,
>>> So many thanks form your answer. I've been checking what you told me
>>> and as an attachment you will find the mapbender/log file and below,
>>> there is the result of executing the mapbender_setup.php
>>> For your information, I am (trying) running mapbender 2.6 rc1 on
>>> Ubuntu 8.04.
>>> Any thoughts?
>>> Best regards,
>>> Lluís
>>> *Warning*:
>>> require_once(/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php)
>>> [function.require-once
>>> <http://localhost/mapbender_2.6_rc1//tools/function.require-once>]:
>>> failed to open stream: No such file or directory in
>>> */var/www/mapbender_2.6_rc1/tools/mapbender_setup.php* on line *24*
>>> *Fatal error*: require_once() [function.require
>>> <http://localhost/mapbender_2.6_rc1//tools/function.require>]:
>>> Failed opening required
>>> '/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php'
>>> (include_path='.:/usr/share/php:/usr/share/pear') in
>>> En/na Michael Schulz ha escrit:
>>>> Hi Lluís,
>>>> welcome on board :-)
>>>> Could you have a look at the mapbender log file that is created in the
>>>> /mapbender/log dir? Also it may be helpful to have a look at the
>>>> output of mapbender_setup.php. Open this script in your browser and it
>>>> will show a lot of information regarding mapbender/database
>>>> surroundings. Also, a look in the apache/php error log may give some
>>>> information.
>>>> Please post any valuable information.
>>>> Cheers, Michael
>>>> 2009/7/7 Lluís Vicens <lluis at sigte.udg.es>:
>>>>> Hi,
>>>>> I'm totally newbie to Mapbender and, after completing the
>>>>> installation
>>>>> process (now it seems that all it's ok) I proceed to login
>>>>> (root:root). No
>>>>> errors showed but nothing is loaded :(
>>>>> The only result is just an empty page (see attachment). What's
>>>>> wrong? Any
>>>>> help?
>>>>> Thanks in advance!
>>>>> Lluís
>>>>> map
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
AGIT Konferenz 2009
8.-10. Juli 2009 in Salzburg
http://www.mapbender.org/Mapbender_on_Agit_2009
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
