[Mapbender-users] First steps on Mapbender...
Lluís Vicens lluis at sigte.udg.es
Wed Jul 8 17:02:14 EDT 2009
Ok, I will do it tomorrow morning.
Many thanks ;)
Regards,
Lluís
2009/7/8 Astrid Emde <astrid.emde at wheregroup.com>
> Hello Lluís,
> there is another SQL update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql
> You should run this aswell to correspond with the Mapbender 2.6 code.
> have fun astrid
> Lluís Vicens schrieb:
>> Hi Astrid and Armin,
>> It works! Thanks for your help. I've updated the mapbender database
>> executing the correct sql (update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql) and then,
>> I downloaded mapbender from branches 2.6 and I replaced the old folders and
>> files for the new ones...  I don't know if this is the best way to proceed
>> but it works ;)
>> Now, I'm starting to work on mapbender and take for sure that I will come
>> back with tons of doubts :-[
>> Regards,
>> Lluís
>> En/na Astrid Emde ha escrit:
>>> Hello Llius,
>>> I hope you took the Mapbender 2.6 from braches/2.6
>>> You can donload it from
>>> http://trac.osgeo.org/mapbender/browser/branches/2.6
>>> (We did a lot of bugfixxes since Mapbender 2.6rc1, so it makes sense to
>>> take the package from /branches/2.6)
>>> The error in the logfile says. ERROR:  relation "gui_gui_category" does
>>> not
>>> It seems that you don't have run the sql for the mapbender installation
>>> properly (one table gui_gui_category is missing)
>>> Please recreate your Database! You find an installation script at
>>> mapbender/resources/db/install_2.6.sh (install_2.6.bat for windows)
>>> which will lead you easily through the installation.
>>> Then you just have to point the mapbender.conf to this new database.
>>> If you still have problems let us know.
>>> Astrid
>>>> Hi Michael,
>>>> So many thanks form your answer. I've been checking what you told me and
>>>> as an attachment you will find the mapbender/log file and below, there is
>>>> the result of executing the mapbender_setup.php
>>>> For your information, I am (trying) running mapbender 2.6 rc1 on Ubuntu
>>>> 8.04.
>>>> Any thoughts?
>>>> Best regards,
>>>> Lluís
>>>> *Warning*:
>>>> require_once(/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php)
>>>> [function.require-once <
>>>> http://localhost/mapbender_2.6_rc1//tools/function.require-once>]:
>>>> failed to open stream: No such file or directory in
>>>> */var/www/mapbender_2.6_rc1/tools/mapbender_setup.php* on line *24*
>>>> *Fatal error*: require_once() [function.require <
>>>> http://localhost/mapbender_2.6_rc1//tools/function.require>]: Failed
>>>> opening required
>>>> '/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php'
>>>> (include_path='.:/usr/share/php:/usr/share/pear') in
>>>> En/na Michael Schulz ha escrit:
>>>>> Hi Lluís,
>>>>> welcome on board :-)
>>>>> Could you have a look at the mapbender log file that is created in the
>>>>> /mapbender/log dir? Also it may be helpful to have a look at the
>>>>> output of mapbender_setup.php. Open this script in your browser and it
>>>>> will show a lot of information regarding mapbender/database
>>>>> surroundings. Also, a look in the apache/php error log may give some
>>>>> information.
>>>>> Please post any valuable information.
>>>>> Cheers, Michael
>>>>> 2009/7/7 Lluís Vicens <lluis at sigte.udg.es>:
>>>>>> Hi,
>>>>>> I'm totally newbie to Mapbender and, after completing the installation
>>>>>> process (now it seems that all it's ok) I proceed to login
>>>>>> (root:root). No
>>>>>> errors showed but nothing is loaded :(
>>>>>> The only result is just an empty page (see attachment). What's wrong?
>>>>>> Any
>>>>>> help?
>>>>>> Thanks in advance!
>>>>>> Lluís
>>>>>> map
>>>>>> _______________________________________________
>>>>>> Mapbender_users mailing list
>>>>>> Mapbender_users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> AGIT Konferenz 2009
> 8.-10. Juli 2009 in Salzburg
> http://www.mapbender.org/Mapbender_on_Agit_2009
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20090708/e61cc69b/attachment.html
More information about the Mapbender_users mailing list
