[Mapbender-users] how to integrate a static legendimage which describe a classified raster map
Peter Freimuth freimuth at rapideye.de
Mon Jun 15 12:40:18 EDT 2009
Hi Michael,
thanks for the quick response and sorry list for sending the request again.
Yes, we have more than one layer in the request. I will try to modify the mapbender db but maybe somebody could give me a hint which table to start with if i want to change the get legend url request for a layer in the wms.
Kind regards,
Peter
On Monday 15 June 2009 18:16:46 Michael Schulz wrote:
> Hi Peter,
> is this the only layer in the mapfile? If so, you should be able to
> tell the legend obj to create a legend in the size of your keyimage,
> and this should be reflected accordingly in the capabilities
> legendgraphic section.
> The two other mapbender approaches would be:
> 1) modify the the getcapabilties-doc manually and don't load the
> mapserver dynamic one
> 2) modify the mapbender db directly...
> But a better solution would be a mapserver enhancement, that would let
> you define a layer's static legendicon url via a metadata keyword.
> Cheers, Michael
> 2009/6/15 Peter Freimuth <freimuth at rapideye.de>:
> > Hi,
> > i would like to use a scecial image like the attached file as an LegendIcon for a raster layer in mapbender 2.5- The Layer is served by a UMN and i know that there is a special attribute called KEYIMAGE which can be used for this. But of course mapbender will request this image with the same size than all other images.
> >        CLASS
> >            NAME "GC Map"
> >            KEYIMAGE "images/GroundCover.png"
> >        END
> > Any idea,
> > Peter
> > _______________________________________________________________________
> > Peter Freimuth                          phone: +49 3381 8904327
> > Product Development                     fax:   +49 3381 8904101
> > RapidEye AG                             email: freimuth at rapideye.de
> > Molkenmarkt 30
> > 14776 Brandenburg an der Havel          http://www.rapideye.de
> > Germany
> > PRIVILEGE AND CONFIDENTIALITY NOTICE:
> > The information in this email is intended for the named recipients
> > only. It may contain privileged and confidential information.  If you
> > have received this communication in error, any use, copying or
> > dissemination of its contents is strictly prohibited.  Please erase all
> > copies of the message along with any included attachments and notify
> > RapidEye AG or the sender immediately by telephone at the number
> > indicated on this page.
> > RapidEye AG
> > Molkenmarkt 30
> > Germany
> > Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
> > Management Board/Vorstand: Wolfgang G. Biedermann
> > Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
> > Commercial Register/Handelsregister Potsdam HRB 17 796
> > Tax Number/Steuernummer: 048/100/00053
> > VAT-Ident-Number/Ust.-ID: DE 199331235
> > DIN EN ISO 9001 certified
> > Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
> > Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> > E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
> > Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
> > die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> > The information in this e-mail is intended for the named recipients
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
Molkenmarkt 30
Germany
RapidEye AG
Molkenmarkt 30
Germany
More information about the Mapbender_users mailing list
