[Mapbender-users] how to integrate a static legendimage which
describe a classified raster map
Michael Schulz
mschulz at webgis.de
Mon Jun 15 15:09:23 EDT 2009
Hi Peter,
you have to modify table "layer_style". Be careful to change the value
of the legendurl of the layers style that is defined in
gui-wms-settings (default is "default").
Needless to say, this change will be lost with the next update of the
corresponding wms ...
Cheers, Michael
2009/6/15 Peter Freimuth <freimuth at rapideye.de>:
> Hi Michael,
> thanks for the quick response and sorry list for sending the request again.
> Yes, we have more than one layer in the request. I will try to modify the mapbender db but maybe somebody could give me a hint which table to start with if i want to change the get legend url request for a layer in the wms.
> Kind regards,
> Peter
> On Monday 15 June 2009 18:16:46 Michael Schulz wrote:
>> Hi Peter,
>> is this the only layer in the mapfile? If so, you should be able to
>> tell the legend obj to create a legend in the size of your keyimage,
>> and this should be reflected accordingly in the capabilities
>> legendgraphic section.
>> The two other mapbender approaches would be:
>> 1) modify the the getcapabilties-doc manually and don't load the
>> mapserver dynamic one
>> 2) modify the mapbender db directly...
>> But a better solution would be a mapserver enhancement, that would let
>> you define a layer's static legendicon url via a metadata keyword.
>> Cheers, Michael
>> > Hi,
>> > i would like to use a scecial image like the attached file as an LegendIcon for a raster layer in mapbender 2.5- The Layer is served by a UMN and i know that there is a special attribute called KEYIMAGE which can be used for this. But of course mapbender will request this image with the same size than all other images.
>> > CLASS
>> > NAME "GC Map"
>> > KEYIMAGE "images/GroundCover.png"
>> > END
>> > Any idea,
>> > Peter
>> > _______________________________________________________________________
>> > Peter Freimuth phone: +49 3381 8904327
>> > Product Development fax: +49 3381 8904101
>> > RapidEye AG email: freimuth at rapideye.de
>> > Molkenmarkt 30
>> > 14776 Brandenburg an der Havel http://www.rapideye.de
>> > Germany
>> > PRIVILEGE AND CONFIDENTIALITY NOTICE:
>> > The information in this email is intended for the named recipients
>> > only. It may contain privileged and confidential information. If you
>> > have received this communication in error, any use, copying or
>> > dissemination of its contents is strictly prohibited. Please erase all
>> > copies of the message along with any included attachments and notify
>> > RapidEye AG or the sender immediately by telephone at the number
>> > indicated on this page.
>> > RapidEye AG
>> > Molkenmarkt 30
>> > Germany
>> > Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
>> > Management Board/Vorstand: Wolfgang G. Biedermann
>> > Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
>> > Commercial Register/Handelsregister Potsdam HRB 17 796
>> > Tax Number/Steuernummer: 048/100/00053
>> > VAT-Ident-Number/Ust.-ID: DE 199331235
>> > DIN EN ISO 9001 certified
>> > Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
>> > Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
>> > E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
>> > Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
>> > die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
>> > The information in this e-mail is intended for the named recipients
>> > Mapbender_users mailing list
>> > Mapbender_users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Molkenmarkt 30
> Germany
> RapidEye AG
> Molkenmarkt 30
> Germany
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
