[Mapbender-users] MB 2.5: Problems with legends in pdf-print
using mapserver's agg
Michael Schulz
mschulz at webgis.de
Mon Mar 2 08:39:03 EST 2009
Hello Mr. Schönhammer,
are you using imagemode "image/png;24bit mode" for this service in
Mapbender? Then this could be the problem, because printPDF sets the
imageformat for the maps and the legend icons to image/png. Then maybe
your customized outputformat isn't used anymore... In the GUI the
imageformats are used as defined in gui wms settings.
Chees, Michael Schulz
2009/3/2 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
> Hi list,
> I have a new strange problem with pdf-print in Mapbender 2.5.
> Lines should be rendered with rounded linejoins. So I'm using mapserver agg
> - renderer with an outputformat defined like:
> OUTPUTFORMAT
> ##NAME png
> ##DRIVER "GD/PNG"
> MIMETYPE "image/png"
> NAME 'AGGA'
> DRIVER AGG/PNG
> EXTENSION PNG
> IMAGEMODE RGBA
> TRANSPARENT ON
> END
> Things are done well
> in the map
> and in the legend of the gui.
> Things are going wrong in printing the legend in pdf-print.
> The legend picture is drawn with a black background. So the text of the
> legend is not readable anymore. (Please see examples in the appendix)
> Until now I used gd-driver. With gd-driver all things are going right.
> The background of the legend picture is defined transparent. So the same
> legend picture my be used in different guis (with different
> background-color) and in pdf-Print.
> LEGEND
> STATUS ON
> KEYSIZE 298 398
> KEYSPACING 10 1
> LABEL
> TYPE TRUETYPE
> FONT "verdana"
> SIZE 8
> POSITION lc
> END # END LABEL
> TRANSPARENT ON
> IMAGECOLOR 255 255 255
> END #LEGEND
> I'm not able to detect any difference in the pictures produced by gd or by
> agg. In all tools (even photo-editors) the background is displayed
> transparent. Only in mapbender pdf-print the background is displayed in
> black. So I think, the solution could be in pdf-print ?
> Has anybody observed similar problems ?
> Has anybody a tipp ?
> Thanks a lot
> Herbert Schönhammer
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
