AW: [Mapbender-users] MB 2.5: Problems with legends in pdf-print using mapserver's agg
Schönhammer, Herbert Schoenhammer.Herbert at Regensburg.de
Mon Mar 2 10:18:07 EST 2009
Hi Michael,
sorry I don't really understand your hint :-(
At the moment I use (wms-gui-settings): "image/png"
But there is no difference between "image/png" and "image/png; mode=24bit".
Only the settings in the mapfile determine the outputformat. So the following always generates a 8bit output. In this case, the printig of the picture in the legend is okay, but the quality of the map is very very poor.
# 8 Bit Farbe
OUTPUTFORMAT
    NAME 'AGG_Q'
    DRIVER AGG/PNG
    IMAGEMODE RGB
    FORMATOPTION "QUANTIZE_FORCE=ON"
    FORMATOPTION "QUANTIZE_DITHER=OFF"
    FORMATOPTION "QUANTIZE_COLORS=256"
END
So I want a map with 24bit color.
Please: Could you give me some more hints?
What shall I use ? "image/png" or "image/png; mode=24bit" in wms-settings?
What settings in the mapfile should be done in this case ?
regards
Herbert Schönhammer
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Michael Schulz
>Gesendet: Montag, 2. März 2009 14:39
>An: Mapbender User List
>Betreff: Re: [Mapbender-users] MB 2.5: Problems with legends
>Hello Mr. Schönhammer,
>are you using imagemode "image/png;24bit mode" for this service in
>Mapbender? Then this could be the problem, because printPDF sets the
>imageformat for the maps and the legend icons to image/png. Then maybe
>your customized outputformat isn't used anymore... In the GUI the
>imageformats are used as defined in gui wms settings.
>Chees, Michael Schulz
>2009/3/2 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
>> Hi list,
>> I have a new strange problem with pdf-print in Mapbender 2.5.
>> Lines should be rendered with rounded linejoins. So I'm
>using mapserver agg
>> - renderer with an outputformat defined like:
>> OUTPUTFORMAT
>>    ##NAME png
>>    ##DRIVER "GD/PNG"
>>    MIMETYPE "image/png"
>>    NAME 'AGGA'
>>    DRIVER AGG/PNG
>>    EXTENSION PNG
>>    IMAGEMODE RGBA
>>    TRANSPARENT ON
>> END
>> Things are done well
>> in the map
>> and in the legend of the gui.
>> Things are going wrong in printing the legend in pdf-print.
>> The legend picture is drawn with a black background. So the
>text of the
>> legend is not readable anymore. (Please see examples in the appendix)
>> Until now I used gd-driver. With gd-driver all things are
>going right.
>> The background of the legend picture is defined transparent.
>So the same
>> legend picture my be used in different guis (with different
>> background-color) and in pdf-Print.
>> LEGEND
>>   STATUS ON
>>   KEYSIZE 298 398
>>   KEYSPACING 10 1
>>   LABEL
>>     TYPE TRUETYPE
>>     FONT "verdana"
>>     SIZE 8
>>     POSITION lc
>>   END # END LABEL
>>   TRANSPARENT ON
>>   IMAGECOLOR 255 255 255
>> END   #LEGEND
>> I'm not able to detect any difference in the pictures
>produced by gd or by
>> agg. In all tools (even photo-editors) the background is displayed
>> transparent. Only in mapbender pdf-print the background is
>displayed in
>> black. So I think, the solution could be in pdf-print ?
>> Has anybody observed similar problems ?
>> Has anybody a tipp ?
>> Thanks a lot
>> Herbert Schönhammer
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>Michael Schulz
>mschulz at webgis.de
>in medias res
>Gesellschaft für Informationstechnologie mbH
>In den Weihermatten 66
>79108 Freiburg
>Tel  +49 (0)761 556959-5
>Fax +49 (0)761 556959-6
>http://www.webgis.de / http://www.zopecms.de
>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
