[Mapbender-users] GUI elements are not arranged in iframe
adoering
doering at sad-net.de
Tue Oct 6 18:08:01 EDT 2009
Hello Sebastian,
did you find any solution for your problem?
I am facing the same problem and couldn't find a solution yet.
Best regards
Andreas Doering
Sebastian Krohn-Grimberghe wrote:
> Hello,
> I’m trying to integrate a GUI into a HTML site by loading it into an
> iframe
> with version 2.6. Up to version 2.5.2 this worked fine. But with version
> 2.6
> the elements which are arranged depending on the map frame position (e.g.
> navFrame and dragMapSize) are not arranged around the map. Instead they
> are
> displayed on their initial position (e.g. top: 0, left: 0) and don’t work.
> If I load the GUIs directly and not in an iframe everything works fine.
> If the HTML file with the iframe is called from a different host than
> Mapbender, firebug often displays an error message that the Mapbender host
> doesn’t have the permission to read the attribute “Window.eventInitMap”.
> If
> both runs on the same host I don’t get error messages from firebug, but
> still the same elements are not arranged. It makes no difference whether I
> use my own customized GUIs or the existing templates.
> Does anyone know how I get all elements arranged correctly in the iframe
> with version 2.6?
> Best regards,
> Entwicklung
> IP SYSCON GmbH
> Tiestestraße 16-18
> D-30171 Hannover
> Tel.: +49 (511) 85 03 03 - 0
> Fax: +49 (511) 85 03 03 - 30
> E-Mail: sebastian.krohn-grimberghe at ipsyscon.de
> http://www.ipsyscon.de/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
View this message in context: http://n2.nabble.com/GUI-elements-are-not-arranged-in-iframe-tp3705804p3778428.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users
