[Mapbender-users] GetFeatureInfo on WMS
Michael Schulz mschulz at webgis.de
Mon Sep 28 10:50:35 EDT 2009
could you give us more information on what version of mapbender you
are using? Is this error happening in a standard gui or in a self-made
gui?
Greetings, Michael
2009/9/28 Robert Walter <robert-walter at gmx.de>:
> Hi list,
> I have a problem with getfeatureinfo-requests on WMS-layers. In the mapfile of the wms a template for each layer is defined. I use the featureinfotunnel with the new popup-module.
> When the wms is enabled and visible in Mapbender the getfeatureinfo-request shows the correct info. But when the wms is turned off in treegde-module or the wms-layer is invisible because of its scale, the getfeatureinfo shows the following error:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="LayerNotDefined">
> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
> </ServiceException>
> </ServiceExceptionReport>
> What can I do, to avoid this behaviour. When there is no object visible, the getfeatureinfo-request should return no result and must not open the popup.
> Greeting RW
> Jetzt kostenlos herunterladen: Internet Explorer 8 und Mozilla Firefox 3.5 -
> sicherer, schneller und einfacher! http://portal.gmx.net/de/go/atbrowser
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Besuchen Sie uns auf der INTERGEO 2009: 22.09. - 24.09.2009 in Karlsruhe;
Halle 1, Stand 1.417
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
