****SPAM Mail****[Mapbender-users] Fehler beim Hochladen der
Capabilities
martina ikert
martinaikert at hotmail.com
Wed Feb 3 11:48:43 EST 2010
Ausgabe bei Angabe von
TEMPLATE
"http://foehr.xxx.de:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen":
foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # wget -O /tmp/caps.xml
http://foehr.xxx.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
[1] 32326
[2] 32327
[3] 32328
--17:02:13--
=> `/tmp/caps.xml'
Resolving foehr.xxx.de...
foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # 127.0.0.2
Connecting to foehr.xxx.de|127.0.0.2|:8080... connected.
HTTP request sent, awaiting response... 302 Found
[following]
--17:02:13--
=> `/tmp/caps.xml'
Reusing existing connection to foehr.xxx.de:8080.
http://foehr.xxx.de:8080/mapbender1/http/frames/login.php [following]
--17:02:13--
=> `/tmp/caps.xml'
HTTP request sent, awaiting response... 200 OK
Length: 1,161 (1.1K) [text/html]
100%[========================================================================================>]
1,161 --.--K/s
17:02:13 (70.13 MB/s) - `/tmp/caps.xml' saved [1161/1161]
[1] Done wget -O /tmp/caps.xml
[2]- Done REQUEST=GetCapabilities
[3]+ Done SERVICE=WMS
Inhalt von caps.xml:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
Licensing: See the GNU General Public License for more details.
http://www.gnu.org/copyleft/gpl.html
or:
mapbender/licence/
<meta http-equiv="cache-control" content="no-cache">
<meta http-equiv="pragma" content="no-cache">
<meta http-equiv="expires" content="0">
<meta http-equiv="Content-Type" content="text/html;
charset=UTF-8"><title>Login</title>
<link rel="stylesheet" type="text/css" href="../css/login.css"><script
type='text/javascript'><!--
function
setFocus(){if(document.loginForm){document.loginForm.name.focus();}}// -->
</script></head><body onload='setFocus()'><form name='loginForm' action
='' method='POST'><table><tr><td>Name: </td><td><input type=
'text' name='name' class='login_text'
value=''></td></tr><tr><td>Password: </td><td><input type='password'
name='password' class='lo
gin_text'></td></tr><tr><td></td><td><input type='submit'
class='myButton' value='login' title='anmelden'> <a href='../ph
p/mod_forgottenPassword.php' title='Passwort vergessen?'
target='_blank'>Forgot your password?</a></td></tr></table></form></body>
</html>
TEMPLATE
"/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&gui_id=Expeditionen":
foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # more /tmp/caps.xml
Content-type: text/html
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS
=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORT
S=GEOS SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF">
msReturnPage(): Web application error. Malformed template name
(/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&
amp;gui_id=Expeditionen).
</BODY></HTML>
[1] 32231
[2] 32232
[3] 32233
--16:48:35--
=> `/tmp/caps.xml'
Resolving foehr.xxx.de... 127.0.0.2
Length: unspecified [text/html]
] 569 --.--K/s
16:48:35 (33.86 MB/s) - `/tmp/caps.xml' saved [569]
<HTML>
INPUT=SHAPEFILE -->
mapserv(): Web application error. Traditional BROWSE mode requires a
TEMPLATE in the WEB section, but none was provided.
</BODY></HTML>
Deine Erläuterungen zum TEMPLATE habe ich nicht verstanden.
Wie muss ich in der map-Datei im TEMPLATE die Anbindung zur Mapbender GUI machen. Ich habe ja keine html-Seite als template.
Ich weiß leider nicht mehr, wo ich diese Anweisung im TEMPLATE gelesen habe, aber lokal hat es immer geklappt.
Viele Grüße
Martina
> Date: Mon, 1 Feb 2010 11:46:12 +0100
> Subject: Re: ****SPAM Mail****[Mapbender-users] Fehler beim Hochladen der Capabilities
> From: mschulz at webgis.de
> To: mapbender_users at lists.osgeo.org
> Hallo Martina,
> könntest Du mal den Inhalt des Ergebnisses des letzten wget Aufrufes
> posten? Mit dem Flag wget -O landet ja das Ergebnis in einer Datei (am
> besten irgendwo im /tmp), dieses Ergebnis kann der Mapbender noch
> nicht korrekt parsen, daher kommt noch der Fehler. Es ist also nicht
> nur $1 leer, sondern alle Variablen - aber der erste verletzte
> Constraint in der DB löst halt den Fehler aus. Von demher ist die
> Fehlermeldung etwas irreführend. Wichtig wäre also weiterhin die
> Antwort eures GetCapabilities-Aufrufes per wget zu checken (und evtl.
> hier zu posten).
> Eine Sache zum Mapserver loggen: Im "normalen" Mapserver-Log (das per
> LOG angesprochen wird) erhältst Du zwar letztendlich eine
> Fehlermeldung aber kein Debug-output. "Richtiges" debugging am besten
> per CONFIG "MS_ERRORFILE" "/tmp/mapserver.log" im MAP-Objekt und DEBUG
> on bei den Layern aktivieren.
> Zum TEMPLATE: Bist Du Dir sicher, dass Du im TEMPLATE wieder ein
> Mapbender-GUI aufrufen willst? Als erstes würde ich mal einfach einen
> dummy-template Eintrag nehmen (TEMPLATE "dummy") , das dazu führt,
> dass die Ebene abfragbar ist. Dann bei den GUI-WMS-Einstellungen als
> info/format "text/plain" auswählen.
> Viele Grüße, Michael
> Am 1. Februar 2010 10:32 schrieb martina ikert <martinaikert at hotmail.com>:
> > Hallo Michael,
> > am Freitag abend konnten wir wieder ein bisschen ausprobieren.
> > Wir haben die Funktion wget benutzt und bekamen einige Fehlermeldungen, die
> > wir nach und nach bereinigen konnten.
> > Zuletzt hatten wir folgende Fehlermeldung:
> > Ältere behobener Inhalt: von "rlp.log":
> > Fri Jan 29 16:51:26 2010,14722,127.0.0.2,Vessels,0,-180.004167
> > -164.995833 179.995833 195.004167,-1.000000 -1.000000,,msReturnPage
> > (/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&gui_id=Exp
> > editionen). <br>
> > Daraufhin haben wir in der map-Datei folgendes ausprobiert, obwohl
> > unlogisch, nach untenstehenden Definitionen:
> > TEMPLATE
> > "http://ServerURL:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen"
> > #### TEMPLATE
> > Aktuellster Inhalt der rlp.log:
> > Fri Jan 29 17:12:24 2010,15153,127.0.0.2,Vessels,0,-180.004167
> > -164.995833 179.995833 195.004167,-1.000000 -1.000000,,normal execution
> > Es gibt also in der log-Datei keine Fehlermeldungen mehr, aber die
> > Fehlermeldung beim Hochladen der Capabilities besteht.
> > Dazu mal die Eintragung in der pgsql-log:
> > 2010-01-29 17:14:55 CET mapbender postgres FEHLER: NULL-Wert in Spalte
> > »wms_title« verletzt Not-Null-Constraint
> > 2010-01-29 17:14:55 CET mapbender postgres ANWEISUNG: UPDATE wms SET
> > wms_title = $1 ,wms_abstract = $2 ,fees = $3, accessconstr
> > aints = $4, contactperson = $5,
> > ($1 <-- ist anscheind wirklich leer, woher kommt $1 ??
> > Was bei unserem WebGIS an sich noch nicht funktioniert ist die
> > featureInfo-Funktion.
> > Bei einem Klick auf eine Stationskoordinate öffnen sich immer 2
> > leere Fenster, nicht aber das HTML-Template. In einer Tabelle sollten die
> > Daten zu der Station zu lesen sein.
> > Wie kommen wir da weiter?
> > Viele Grüße
> > Martina
> > Auszug aus meinen Recherchen:
> > They guide the presentation of results, either a query or a map, to the
> > user. Templates are almost always HTML files although they can also be a URL
> > (e.g.. http://www.somewhere.com/[ATTRIBUTE]/info.html). URL templates can
> > only be used with simple QUERY or ITEMQUERY results so many substitutions
> > defined below are not available for them. Simple pan/zoom interfaces use a
> > single template file while complicated queries often require many templates.
> > Templates often use JavaScript to enhance the basic interface.
> > msReturnPage(): Web application error. Malformed template name¶
> > This error may occur when you are attempting to use a URL template for a
> > query. The issue is that URL templates are only allowed for query modes that
> > return only one result (e.g. query or itemquery)
> > You can only use a URL template for a query in mode=query or mode=itemquery.
> > If you try it with mode=nquery or mode=itemnquery, you will get the error:
> > Content-type: text/html msReturnPage(): Web application error. Malformed
> > template name
> >> Date: Thu, 21 Jan 2010 09:17:58 +0100
> >> Capabilities
> >> Hallo Martina,
> >> klar, das ist die Fehlermeldung im Mapbender-Log. Wenn der Mapbender
> >> meldet das die WMS-Version die Not-Null Bedingung verletzt ("Error:
> >> FEHLER: NULL-Wert in Spalte »wms_version« verletzt
> >> Not-Null-Constraint"), heißt das soviel wie, das in der Antwort auf
> >> die GetCapabilities-Anfrage vermutlich gar keine WMS-Getcapabilities
> >> drinnen sind. Daher hatte Armin schon vorgeschlagen:
> >> "in der class_connector.php function load einfach mal ein $e=new
> >> mb_exception('class_connector.php: loaded external data: ',$data);
> >> eintragen
> >> (vor der return.. zeile)"
> >> also ein zusätzlichen Log-Eintrag zu erstellen. Der bisherige Auszug
> >> aus dem Logfile zeigt die Standard-Fehlermeldung vom Mapbender, der
> >> zusätzliche Eintrag würde Dir den Inhalt der GetCapabilities-Antwort
> >> im Log anzeigen. Als quasi äquivalente Möglichkeit kannst Du den
> >> GetCapabilities Aufruf auch von dem Mapbender-Server (aber nicht aus
> >> der Mapbender-Oberfläche) per wget absetzen um mal zu sehen, was da
> >> eigentlich zurückkommt.
> >> Am 21. Januar 2010 08:38 schrieb martina ikert <martinaikert at hotmail.com>:
> >> > Hallo Michael,
> >> > ich habe dir noch einmal die Fehlermeldung kopiert. Das war der Tipp von
> >> > Armin.
> >> > 2010.01.15, 17:59:48,mb_validateSession.php: GUI: admin2_de, checking
> >> > file /mapbender1/http/php/mod_updateWMS.php...session valid.
> >> > 2010.01.15, 17:59:48,mb_validatePermission.php: checking file
> >> > /mapbender1/http/php/mod_updateWMS.php...permission valid.
> >> > 2010.01.15, 17:59:48,connector: unable to load:
> >> > http://our-server.domaine.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> >> > 2010.01.15, 17:59:48,Error while executing prepared statement in
> >> > /tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/php/mod_updateWMS.php:
> >> > Sql: UPDATE wms SET wms_version = $1 ,wms_getcapabilities = $2
> >> > ,wms_getmap = $3 ,wms_getfeatureinfo = $4 ,wms_getlegendurl = $5
> >> > ,wms_getcapabilities_doc = $6 ,wms_upload_url = $7, wms_owner = $8,
> >> > wms_timestamp = $9 WHERE wms_id = $10, Error: FEHLER: NULL-Wert in
> >> > Spalte »wms_version« verletzt Not-Null-Constraint
> >> > Viele Grüße
> >> > Martina
> >> >> Date: Wed, 20 Jan 2010 16:25:38 +0100
> >> >> der
> >> >> Capabilities
> >> >> Hallo Martina,
> >> >> kannst Du dich auf dem Server wo der Mapbender läuft einloggen und
> >> >> dort auf der Kommandozeile mal folgenden Befehl absetzen:
> >> >> "http://our-server.domaine.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1"
> >> >> Dann sollte in der Datei caps.xml im /tmp Verzeichnis die Antwort auf
> >> >> die GetCapabilities-Anfrage stehen, was recht wahrscheinlich
> >> >> irgendeine Fehlermeldung sein wird. Das ist ungefähr das gleiche, wie
> >> >> es Armin Retterath schon vorgeschlagen hat, aber ich hatte nichts
> >> >> gefunden im thread, ob Du das mal probiert hast.
> >> >> Am 20. Januar 2010 16:03 schrieb martina ikert
> >> >> > Hallo Karim,
> >> >> > in php.ini ist
> >> >> > allow_url_fopen = On
> >> >> > Wir haben heute wieder viel rumprobiert, aber es ist keine Lösung in
> >> >> > Sicht.
> >> >> > Beim Upload der Capabilities gibt es immer noch die gleiche
> >> >> > Fehlermeldung.
> >> >> > So langsam ist es wirklich frustrierend.
> >> >> > Hat denn sonst niemand lokal gearbeitet und hat dann die Dateien auf
> >> >> > einen
> >> >> > Server installiert?
> >> >> > Viele Grüße
> >> >> > Martina
> >> >> >> Date: Mon, 18 Jan 2010 11:15:20 +0100
> >> >> >> From: karim at malhas.de
> >> >> >> Hochladen
> >> >> >> der
> >> >> >> Capabilities
> >> >> >> Hallo Martina,
> >> >> >> > Hat jemand noch einen guten Tipp?
> >> >> >> Schau mal nach ob in deiner php.ini
> >> >> >> gesetzt ist.
> >> >> >> Gruß,
> >> >> >> Karim
> >> >> >> _______________________________________________
> >> >> >> Mapbender_users mailing list
> >> >> >> Mapbender_users at lists.osgeo.org
> >> >> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> >> >> > Windows Live: Keep your friends up to date with what you do online.
> >> >> Aufwind durch Wissen!
> >> >> Qualifizierte Open Source Schulungen bei der
> >> >> http://www.foss-akademie.de/
> >> >> Michael Schulz
> >> >> in medias res
> >> >> Gesellschaft für Informationstechnologie mbH
> >> >> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
> >> >> Schwimmbadstraße 2
> >> >> D-79100 Freiburg i. Br.
> >> >> Tel: +49 (0)761 705798-102
> >> >> Tel: +49 (0)761 705798-0
> >> >> Fax: +49 (0)761 705798-09
> >> >> http://www.webgis.de / http://www.zopecms.de
> >> >> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> >> >> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
> >> > Windows Live Hotmail: Your friends can get your Facebook updates, right
> >> > from
> >> > Hotmail®.
> >> Michael Schulz
> >> in medias res
> >> Schwimmbadstraße 2
> > Hotmail: Trusted email with powerful SPAM protection. Sign up now.
> Michael Schulz
> in medias res
> Schwimmbadstraße 2
_________________________________________________________________
Hotmail: Powerful Free email with security by Microsoft.
https://signup.live.com/signup.aspx?id=60969
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20100203/f2de91c4/attachment-0001.html
More information about the Mapbender_users
