[Mapbender-users] WFS Search Result Problem
Michael Schulz mschulz at webgis.de
Fri Feb 26 07:35:22 EST 2010
next try: change the type to "MultiPolygonPropertyType".
Cheers, Michael
P.S.: I was struggling with the same stuff recently...
2010/2/26 Andreas Voit <a_voit at gmx.at>:
> hi,
> thanks for your fast answer, i was very astonished ;)
> to my problem.
> - i changed the geoserver wfs settings to normal.
> - i changed to wfs 1.0
> - in the mapbender db was MultiSurfacePropertyType and I changed it to
> MULTIPOLYGON
> but the error still occurs. the epsq should be the same.
> and I also get in the error logfile "WFS gazetteer: geometry type unknown".
> thanks
> Am 26.02.2010 11:12, schrieb Michael Schulz:
>> Hi,
>> welcome to Mapbender!
>> WFS configuration is still a bit complicated, although Mapbender
>> really does a good job with that. Some things to check:
>> - have you uploaded your WFS as version 1.0 or 1.1? With Mapbender 2.6
>> I'd stick to version 1.0
>> - in Geoserver set your WFS-GML-SRS style to "normal" (under Services
>> - WFS, scroll down to the bottom)
>> - check the returned geometryType of your featuretype. I think
>> Mapbender will only handle the "frequently" used ones, like POLYGON,
>> MULTIPOLYGON, LINESTRING, etc... I am not sure why (I think it has to
>> do with what kind of datastore you use), but Geoserver sometimes
>> exposes your featureType as MultiSurfacePropertyType or the like...
>> (if that has happened, you may need to change the geometryType by hand
>> in the mapbender DB)
>> - make sure you connect the wms layer to the right wfs conf (but i
>> think if you already get results, that's already done)
>> - epsg-srs must match between WMS-GUI-setting and WFS featuretype
>> - your coordinate example seems to me as if you bitten by the
>> coordinate axis order confusion with wfs 1.1: see the first point.
>> These are some points to check. Mapbender 2.6 should work well with
>> Geoserver 2.0.1, at least I have it working with epsg:31467.
>> Have fun, Michael
>>> hello,
>>> I'm new to mapbender. I use mapbender 2.6, postgresql 8.4, geoserver
>>> 2.01, xampp 1.7.3, windows xp sp3, firefox 3.6 .
>>> To my problem:
>>> I use geoserver as my datacenter. I use the wms to show my maps. I
>>> started to use wfs for searching. Therefor I use the gazetteerwfs
>>> module. Over the WFS come multipolygons from my postgresql db.
>>> My Problem occurs when I use the searching. I use a dropdown menu to
>>> select a value. the selection finds the correct feature and when I click
>>> at the result it starts zooming. But it ends up with a white map. When I
>>> mouse over the result, the polygon gets highlighted.
>>> I found out, that the zoomed feature has incorrect coordinates.
>>> I mean the correct coordinates are for example 734078.4, 214992.6 and
>>> the zoomed feature has 214992.6, 734078.4.
>>> I use EPSG 31259.
>>> To find a solution I used firebug. I found the function setResult(event,
>>> index) under http/javascript/mod_wfs_gazetteer_client.php and chanced
>>> the extend calculation to
>>> parent.mb_calculateExtent(targetArray[0], bbox[0].y, bbox[0].x,
>>> bbox[1].y, bbox[1].x); .
>>> After that the wfs search result zoomed to the correct extend, but the
>>> highlighting doesn't show up. In my opinon the highlight feature
>>> coordinates are still uncorrect.
>>> I also should mention, I looked into the mapbender logfiles and found
>>> out, that when I press the wfs search button, it writes an error into
>>> the logfile: [TIMESTAMP] ERROR: WFS gazetteer: geometry type unknown.
>>> could that be the problem for the incorrect coordinates? I also don't
>>> understand the unknown geometry type error.
>>> does anybody know how to fix the coordinate problem?
>>> thanks
>>> Andreas Voit
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Andreas Voit
> http://andreasvoit.heim.at/
> Windows kam, sah und versagte
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
