[Mapbender-users] Installing Mapbender from SVN-trunk, some general questions
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Wed Jan 20 08:37:15 EST 2010
Marc Jansen schrieb:
> Hi Christoph,
> thanks for your responses, I'll try to ignore the notices/errors in
> the GUIs right now, as it's not a stable release I got.
> As for the tools folder: I did a full checkout of the SVN. I *have*
> the folder tools in my repository checkout, but I did  not copy /
> export that particular folder to the  publishing directory of my
> Apache. Why didn't I do that, you ma ask yourself... well as I said:
> That folder is not listed in  'Install.txt' so I  thought that it was
> optional for an installation. It seems to me though, that it isn't
> optional but needed when installing via install.sh or when  I18n is
> needed.
I finally managed to understand. You are right. I added the folder to
the list in the install help file. Thanks for your contribution,
Christoph
> It is an absolute minimal change/problem.
> Regards,
> marc
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
