[Mapbender-users] Digitizing polygons with en- or exclaves
    Michael Schulz
    mschulz at webgis.de
    Tue Jun 29 06:19:54 EDT 2010
Hi Boris,
ok,this error seems to me, that the curl request even cannot reach the
geoserver instance, but I will nevertheless file a ticket about my
curl problem (http://trac.osgeo.org/mapbender/ticket/651). Thanks for
your confirmation that you were using http, when everything worked.
Cheers, Michael
2010/6/29 Leukert, Boris <boris.leukert at wald-und-holz.nrw.de>:
> Hi Michael,
> digitizing normal, "simple" polygons is working perfectly. I'm using
> connection type "http".
> The connection type worked for me with version 2.6, version 2.6.1 (from
> svn) and geoserver 2.0.1.
> For testing I changed to connection type "curl" and the digitization
> fails with the following error:
> 2010.06.29, 12:23:28,Notice: CURL host:127.0.0.1
> 2010.06.29, 12:23:43,ERROR: connector: unable to load:
> http://127.0.0.1:8080/geoserver/wfs
> 2010.06.29, 12:23:43,ERROR: OWS request returned no result:
> Best regards,
> Boris
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
