[Mapbender-users] Digitizing polygons with en- or exclaves
Armin Retterath armin.retterath at lvermgeo.rlp.de
Tue Jun 29 06:51:42 EDT 2010
hi all,
maybe someone forgot to set the proxy exception for 127.0.0.1 in
mapbender.conf?
regards
armin
Am Dienstag 29 Juni 2010 12:19:54 schrieb Michael Schulz:
> Hi Boris,
> ok,this error seems to me, that the curl request even cannot reach the
> geoserver instance, but I will nevertheless file a ticket about my
> curl problem (http://trac.osgeo.org/mapbender/ticket/651). Thanks for
> your confirmation that you were using http, when everything worked.
> Cheers, Michael
> 2010/6/29 Leukert, Boris <boris.leukert at wald-und-holz.nrw.de>:
> > Hi Michael,
> > digitizing normal, "simple" polygons is working perfectly. I'm using
> > connection type "http".
> > The connection type worked for me with version 2.6, version 2.6.1 (from
> > svn) and geoserver 2.0.1.
> > For testing I changed to connection type "curl" and the digitization
> > fails with the following error:
> > 2010.06.29, 12:23:28,Notice: CURL host:127.0.0.1
> > 2010.06.29, 12:23:43,ERROR: connector: unable to load:
> > http://127.0.0.1:8080/geoserver/wfs
> > 2010.06.29, 12:23:43,ERROR: OWS request returned no result:
> > Best regards,
> > Boris
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
