[Mapbender-users] OpenLayers-Mapbender
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Wed Mar 10 09:35:43 EST 2010
Hi Valenty,
thanks for your mail, I'm happy it works.
If you want to add other OpenLayers data sources apart from WMS, I would
be very interested. Currently we are using the module "ol_wms" to read
the WMS settings from Mapbender. Maybe you can create another module,
like "ol_tilecache".
Just an idea.
Best wishes and thanks for letting us know :-)
Christoph
valenty gonzalez schrieb:
> Thanks a lot!
> I have already install the latest version with template_openlayers and
> i had prove it gratefull.
> I agree WMS from Mapbender Administrator and work fine and i have edit
> ol.js with another WMS service (just for prove) and it works. Now i
> will try to prove tilecache with ol.js.
> There is two links below: an image with openlayers_template in my
> "localhost"[1] and a .txt file with "description" in spanish[2] for
> your use if it's useful.
> Regards,
> Valenty Gonzalez
> CREATIVA
> Venezuela
> [1] http://www.creativa-consultores.com/decargas/mapbender_openlayers.png
> [2]
> http://www.creativa-consultores.com/decargas/templ_ol_description_es.txt
> On 8 March 2010 16:30, Christoph Baudson (Wheregroup)
> <christoph.baudson at wheregroup.com
> <mailto:christoph.baudson at wheregroup.com>> wrote:
> Hi there,
> I have exported the current OpenLayers template for Mapbender from
> [1].
> Please download the latest code from SVN via
> svn co https://svn.osgeo.org/mapbender/trunk/mapbender/
> Then install (via resources/install.sh), and finally execute the
> OpenLayers SQL [2]. Please remember to load WMS into this
> application, in our demo we have used [3] and [4].
> If you have any problems, please post to this list.
> Thanks,
> Christoph
> [1]
> http://mapbender.telascience.org/mapbender_trunk/frames/login.php?name=demo&password=demo&mb_user_myGui=template_openlayers
> <http://mapbender.telascience.org/mapbender_trunk/frames/login.php?name=demo&password=demo&mb_user_myGui=template_openlayers>
> [2] http://osgeo.pastebin.com/download.php?i=vZepS6Y1
> [3]
> http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
> <http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS>
> [4]
> http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
> <http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS>
> Hi Christoph, thanks for attend, and sorry for my english.
> I really want to try the current trunk openlayers-mapbender
> integration, i will wait for you instructions.
> Thanks again,
> Valenty Gonzalez
> CREATIVA
> On 22 February 2010 04:42, Christoph Baudson (Wheregroup)
> <mailto:christoph.baudson at wheregroup.com>>> wrote:
> Hi Valenty,
> sorry for replying in english only.
> The OpenLayers modules are compatible only to the latest
> Mapbender
> trunk, which will become version 2.7 soon. If you want to
> try the
> current trunk, let me know and I will give you instructions.
> Christoph
> Valenty Gonzalez schrieb:
> Hola a todos, soy nuevo en la lista y tengo 1 mes
> usando Mapbender
> Es una aplicación excelente y he podido desarrollar un
> par de
> casos de estudio en este período.
> Ahora estoy tratando de hacer la integración con
> OpenLayers,
> pero no sé que parametros colocar para que se activen
> openlayers y openlayers_switch.
> Hay algun SQL que me puedan facilitar para usarlo en la
> base
> de datos?
> Tengo Mapbender_2.6 sobre ubuntu 9.10 y mapserver 5.x
> Hasta ahora cree un elemento openlayers y otro
> openlayers_switch; he colocado de diferentes formas los
> módulos mod_openlayers.php, initWMS_openlayers,
> openlayers.js
> y mod_openlayers_switch y he activado y desactivado
> mapframe1
> haciendo combinaciones pero no visualizo openlayers.
> Gracias,
> Valenty Gonzalez
> CREATIVA
> Venezuela
> Hi everyone, I'm new to the list and I have like one month
> using Mapbender
> It is an excellent application and I have a couple of
> studies
> cases in this period.
> Now I'm trying to do integration with OpenLayers, but I
> don't
> know what parameters set to activate openlayers_switch and
> openlayers.
> Are there any SQL sentence that I can use in the database?
> I have Mapbender_2.6, ubuntu 9.10, mapserver 5.x
> I have tried with create two elements: openlayers and
> openlayers_switch other. I have placed in different
> ways the
> modules: mod_openlayers.php, initWMS_openlayers,
> openlayers.js
> and mod_openlayers_switch, and I have enabled and disabled
> mapframe1 but don't work for me.
> Thank's,
> Valenty Gonzalez
> CREATIVE
> Venezuela
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> <mailto:Mapbender_users at lists.osgeo.org>
> <mailto:Mapbender_users at lists.osgeo.org>>
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> FOSSGIS Konferenz 2010
> 2. - 5. März 2010 in Osnabrück
> http://www.fossgis.de/konferenz
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu <http://www.foss-academy.eu>
> _______________________________________
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com <http://www.wheregroup.com>
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Komplementärin:
> vertreten durch:
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_users
