[Mapbender-users] OpenLayers-Mapbender
    valenty gonzalez
    gvalenty at gmail.com
    Wed Mar 10 09:02:32 EST 2010
Thanks a lot!
I have already install the latest version with template_openlayers and i had
prove it gratefull.
I agree WMS from Mapbender Administrator and work fine and i have edit ol.js
with another WMS service (just for prove) and it works. Now i will try to
prove tilecache with ol.js.
There is two links below: an image with openlayers_template in my
"localhost"[1] and a .txt file with "description" in spanish[2] for your use
if it's useful.
Regards,
Valenty Gonzalez
CREATIVA
Venezuela
[1] http://www.creativa-consultores.com/decargas/mapbender_openlayers.png
[2] http://www.creativa-consultores.com/decargas/templ_ol_description_es.txt
On 8 March 2010 16:30, Christoph Baudson (Wheregroup) <
christoph.baudson at wheregroup.com> wrote:
> Hi there,
> I have exported the current OpenLayers template for Mapbender from [1].
> Please download the latest code from SVN via
> svn co https://svn.osgeo.org/mapbender/trunk/mapbender/
> Then install (via resources/install.sh), and finally execute the OpenLayers
> SQL [2]. Please remember to load WMS into this application, in our demo we
> have used [3] and [4].
> If you have any problems, please post to this list.
> Thanks,
> Christoph
> [1]
> http://mapbender.telascience.org/mapbender_trunk/frames/login.php?name=demo&password=demo&mb_user_myGui=template_openlayers
> [2] http://osgeo.pastebin.com/download.php?i=vZepS6Y1
> [3]
> http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
> [4]
> http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
> valenty gonzalez schrieb:
>> Hi Christoph, thanks for attend, and sorry for my english.
>> I really want to try the current trunk openlayers-mapbender integration, i
>> will wait for you instructions.
>> Thanks again,
>> Valenty Gonzalez
>> CREATIVA
>> On 22 February 2010 04:42, Christoph Baudson (Wheregroup) <
>> christoph.baudson at wheregroup.com <mailto:christoph.baudson at wheregroup.com>>
>> wrote:
>>    Hi Valenty,
>>    sorry for replying in english only.
>>    The OpenLayers modules are compatible only to the latest Mapbender
>>    trunk, which will become version 2.7 soon. If you want to try the
>>    current trunk, let me know and I will give you instructions.
>>    Christoph
>>    Valenty Gonzalez schrieb:
>>        Hola a todos, soy nuevo en la lista y tengo 1 mes usando Mapbender
>>        Es una aplicación excelente y he podido desarrollar un par de
>>        casos de estudio en este período.
>>        Ahora estoy tratando de hacer la integración con OpenLayers,
>>        pero no sé que parametros colocar para que se activen
>>        openlayers y openlayers_switch.
>>        Hay algun SQL que me puedan facilitar para usarlo en la base
>>        de datos?
>>        Tengo Mapbender_2.6 sobre ubuntu 9.10 y mapserver 5.x
>>        Hasta ahora cree un elemento openlayers y otro
>>        openlayers_switch; he colocado de diferentes formas los
>>        módulos mod_openlayers.php, initWMS_openlayers, openlayers.js
>>        y mod_openlayers_switch y he activado y desactivado mapframe1
>>        haciendo combinaciones pero no visualizo openlayers.
>>        Gracias,
>>        Valenty Gonzalez
>>        CREATIVA
>>        Venezuela
>>        Hi everyone, I'm new to the list and I have like one month
>>        using Mapbender
>>        It is an excellent application and I have a couple of studies
>>        cases in this period.
>>        Now I'm trying to do integration with OpenLayers, but I don't
>>        know what parameters set to activate openlayers_switch and
>>        openlayers.
>>        Are there any SQL sentence that I can use in the database?
>>        I have Mapbender_2.6, ubuntu 9.10, mapserver 5.x
>>        I have tried with create two elements: openlayers and
>>        openlayers_switch other. I have placed in different ways the
>>        modules: mod_openlayers.php, initWMS_openlayers, openlayers.js
>>        and mod_openlayers_switch, and I have enabled and disabled
>>        mapframe1 but don't work for me.
>>        Thank's,
>>        Valenty Gonzalez
>>        CREATIVE
>>        Venezuela
>>        _______________________________________________
>>        Mapbender_users mailing list
>>        Mapbender_users at lists.osgeo.org
>>        <mailto:Mapbender_users at lists.osgeo.org>
>>        http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>    FOSSGIS Konferenz 2010
>>    2. - 5. März 2010 in Osnabrück
>>    http://www.fossgis.de/konferenz
>>    Aufwind durch Wissen!
>>    Qualifizierte OpenSource-Schulungen
>>    bei der www.foss-academy.eu <http://www.foss-academy.eu>
>>    W h e r e G r o u p GmbH & Co. KG
>>    Siemensstraße 8
>>    53121 Bonn
>>    Germany
>>    Christoph Baudson
>>    Anwendungsentwickler
>>    Fon: +49 (0)228 / 90 90 38 - 15
>>    Fax: +49 (0)228 / 90 90 38 - 11
>>    www.wheregroup.com <http://www.wheregroup.com>
>>    Amtsgericht Bonn, HRA 6788
>>    Komplementärin:
>>    WhereGroup Verwaltungs GmbH
>>    vertreten durch:
>>    Olaf Knopp, Peter Stamm
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> www.wheregroup.com
> Komplementärin:
> vertreten durch:
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20100310/5f308d1a/attachment-0001.html
More information about the Mapbender_users
