[Mapbender-users] Uploading WMS capabilities of GeoServer
Michael Schulz mschulz at webgis.de
Mon Mar 29 08:29:59 EDT 2010
Hi Jonas,
is Mapbender running on localhost as well? Which connection type did
you configure in mapbender.conf, http or curl? If you are using a
recent Mapbender 2.6, try to use type curl and add localhost to the
NOT_PROXY_HOSTS parameter. Check if this solves your problem.
Cheers, Michael
2010/3/29 Jonas Blasques <tilakapash at gmail.com>:
> Hello,
> I am trying to load the WMS capabilities of the GeoServer sitting in my
> Localhost.
> I followed all the steps from the mapbender tutorial (created new blank GUI
> and then did load WMS).
> I used the following URL:
> http://localhost:8080/geoserver/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> and it gives the xml file which I send in attachment.
> However in the mapbender interface when I submit this url the response is
> just a line:
> file:
> It does and says nothing else.
> Not much of an error response. I have absolutely no idea what is wrong.
> Can someone help ?
> Jonas
> "Ajude um pouco ... já é muito"
> Projecto SOSIndia http://sosindia.net
> Shoot for the moon,
> even if you miss it
> you will land among the stars.
> - Unknown
> What if for a moment, as an experiment,
> you drop every belief that you have?
> - Unknown
> "We are all linked by a fabric of unseen connections. This fabric is
> constantly changing and evolving. This field is directly structured and
> influenced by our behavior and by our understanding."
> —David Bohm, quantum physicist, 1917–1992
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
