[Mapbender-users] Uploading WMS capabilities of GeoServer
Jonas Blasques tilakapash at gmail.com
Mon Mar 29 11:42:03 EDT 2010
Thanks for the quick answer Michael,
I did what you tried and the response is the same although it is now 10X
faster, meaning when I hit the submit button to load the wms it straight
away returns an HTML output and before it was dead slow (I don't know if
this has anything to do with it but i thought of telling you).
Below are the location to which the form of the "upload wms" is sent to
together with the post parameteres.
I also send the request header and the response header.
*I checked the mapbender php modules - mod_loadcapabilities and the
mod_load_wms and the postgres db and saw that the WMS is not being uploaded
to the table wms of the db as is intended with the writeObjInDB($guiList)
function*.
*I think that the code:
$mywms = new wms();
$mywms->createObjFromXML($xml);
$mywms->writeObjInDB($guiList);
$mywms->displayWMS();
has problems wiith the function createObjFromXML($xml)
The parameter $xml seems to be ok (
http://localhost/mapbender/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
I say this because I do var_dumps up to the point after this line and then
no more. I don't know if this is helpful or not.
Any further help is deeply appreciated Michael,
Jonas
LOCATION WITH PARAMETERS
http://localhost/mapbender/php/mod_loadwms.php?&guiID=admin_en_services&elementID=loadWMS&guiList=fdsafdsafdsa&xml_file=http%3A%2F%2Flocalhost%2Fmapbender%2Fwms%3FREQUEST%3DGetCapabilities%26SERVICE%3DWMS%26VERSION%3D1.1.1
REQUEST HEADER
*Host: localhost
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.2.2)
Gecko/20100316 Firefox/3.6.2 (.NET CLR 3.5.30729) FirePHP/0.4
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 115
Connection: keep-alive
Referer:
http://localhost/mapbender/php/mod_loadCapabilities.php?&guiID=admin_en_services&elementID=loadWMS
Cookie: PHPSESSID=8lpi7smghkuntptleva7rr5ee7
*RESPONSE HEADER
*Date: Mon, 29 Mar 2010 14:32:02 GMT
Server: Apache/2.2.14 (Win32) DAV/2 mod_ssl/2.2.14 OpenSSL/0.9.8l
mod_autoindex_color PHP/5.3.1 mod_jk/1.2.28 mod_apreq2-20090110/2.7.1
mod_perl/2.0.4 Perl/v5.10.1
X-Powered-By: PHP/5.3.1
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0,
pre-check=0
Pragma: no-cache
Vary: Accept-Encoding,User-Agent
Content-Encoding: gzip
Content-Length: 104
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Content-Type: text/html*
RESPONSE BODY*
file:
On Mon, Mar 29, 2010 at 1:29 PM, Michael Schulz <mschulz at webgis.de> wrote:
> Hi Jonas,
> is Mapbender running on localhost as well? Which connection type did
> you configure in mapbender.conf, http or curl? If you are using a
> recent Mapbender 2.6, try to use type curl and add localhost to the
> NOT_PROXY_HOSTS parameter. Check if this solves your problem.
> Cheers, Michael
> 2010/3/29 Jonas Blasques <tilakapash at gmail.com>:
> > Hello,
> > I am trying to load the WMS capabilities of the GeoServer sitting in my
> > Localhost.
> > I followed all the steps from the mapbender tutorial (created new blank
> GUI
> > and then did load WMS).
> > I used the following URL:
> http://localhost:8080/geoserver/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> > and it gives the xml file which I send in attachment.
> > However in the mapbender interface when I submit this url the response is
> > just a line:
> > file:
> > It does and says nothing else.
> > Not much of an error response. I have absolutely no idea what is wrong.
> > Can someone help ?
> > Jonas
> > "Ajude um pouco ... já é muito"
> > Projecto SOSIndia http://sosindia.net
> > Shoot for the moon,
> > even if you miss it
> > you will land among the stars.
> > - Unknown
> > What if for a moment, as an experiment,
> > you drop every belief that you have?
> > - Unknown
> > "We are all linked by a fabric of unseen connections. This fabric is
> > constantly changing and evolving. This field is directly structured and
> > influenced by our behavior and by our understanding."
> > —David Bohm, quantum physicist, 1917–1992
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Aufwind durch Wissen!
> Qualifizierte Open Source Schulungen bei der
> http://www.foss-akademie.de/
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Shoot for the moon,
even if you miss it
- Unknown
- Unknown
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20100329/ec7053cd/attachment-0001.html
More information about the Mapbender_users mailing list
