[Mapbender-users] one or two question
zorg zorg at probesys.com
Wed Nov 3 13:24:09 EDT 2010
Hi
in fact I had some bad geom
but now still find nothing but it should not
here is what I have
<wfs:GetFeature service="WFS" version="1.1.0"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc"><wfs:Query
xmlns:demo="http://192.168.12.137/demo"
typeName="demo:parcellaire"><ogc:Filter><Intersects><ogc:PropertyName>demo:wkb_geometry</ogc:PropertyName><gml:Polygon
srsName='EPSG:2154'><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>1916745,4223669
1916745,4224436 1917157,4224436 1917157,4223669
1916745,4223669</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></ogc:Filter></wfs:Query></wfs:GetFeature>
2010.11.03, 18:07:43,Notice: connector.http.postData: <?xml
version="1.0" encoding="UTF-8"?>
2010.11.03, 18:07:43,Notice: connector.http.response: <?xml
<wfs:FeatureCollection numberOfFeatures="0"
timeStamp="2010-11-03T18:07:43.207+01:00"
xsi:schemaLocation="http://192.168.12.137/demo
http://192.168.12.137:80/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=demo%3Aparcellaire
http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
xmlns:tiger="http://www.census.gov"
xmlns:cite="http://www.opengeospatial.net/cite"
xmlns:nurc="http://www.nurc.nato.int"
xmlns:sde="http://geoserver.sf.net"
xmlns:topp="http://www.openplans.org/topp"
xmlns:it.geosolutions="http://www.geo-solutions.it"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:sf="http://www.openplans.org/spearfish"
xmlns:ows="http://www.opengis.net/ows"
xmlns:xlink="http://www.w3.org/1999/xlink"><gml:featureMembers/></wfs:FeatureCollection>
Le 03/11/2010 08:38, Verena Diewald a écrit :
> Hi,
> Am 02.11.2010 22:19, schrieb zorg:
>> Hello
>> I have been testing mapbender for a month and I still have some question
>> My map are using EPSG:2154 but by default mapbender only propose me
>> EPSG:4326   to make it work I have use solution given in this post
>> http://osgeo-org.1803224.n2.nabble.com/Problems-with-EPSG-td2059853.html
>> (doing insert in the database).
>> Is it the good solution
> The point described in the post above is exactly what you have to do.
>> second problem
>> I've been trying to make the Spatial Queries with OGC WFS to work
>> without any success (there is not error it just never found something)
>> I using mapbender  2.6.2,  GeoServer 2.0.2
>> For the moment I have manage to  work with the digitize module and
>> gazetter module using wfs  . I can  create polygon without problem
>> but after I can't find it with the spatial request module.
> Can you give some more information? How does the filter statement for
> the getFeature request look like? To get it, you can set the log level
> in mapbender.conf to "notice", so you can then find the request send
> to GeoServer in the mapbender log file in the log/ folder. Same for
> the digitize transaction request.  You could try to use the getFeature
> xml post request or the transaction request in the GeoServer demo
> request frontend to see what happens.
> Best regards,
> Verena
>> hope someone can help
>> I can give more specific information but I don't really know which
>> one  can help
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
