[Mapbender-users] one or two question
zorg
zorg at probesys.com
Thu Nov 4 06:21:00 EDT 2010
Hello
After more testing it is working if I use WFS version="1.0.0"
is it the only solution
thank for your answer
Le 03/11/2010 18:24, zorg a écrit :
> Hi
> in fact I had some bad geom
> but now still find nothing but it should not
> here is what I have
> <wfs:GetFeature service="WFS" version="1.1.0"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"><wfs:Query
> xmlns:demo="http://192.168.12.137/demo"
> typeName="demo:parcellaire"><ogc:Filter><Intersects><ogc:PropertyName>demo:wkb_geometry</ogc:PropertyName><gml:Polygon
> srsName='EPSG:2154'><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>1916745,4223669
> 1916745,4224436 1917157,4224436 1917157,4223669
> 1916745,4223669</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></ogc:Filter></wfs:Query></wfs:GetFeature>
> 2010.11.03, 18:07:43,Notice: connector.http.postData: <?xml
> version="1.0" encoding="UTF-8"?>
> 2010.11.03, 18:07:43,Notice: connector.http.response: <?xml
> <wfs:FeatureCollection numberOfFeatures="0"
> timeStamp="2010-11-03T18:07:43.207+01:00"
> xsi:schemaLocation="http://192.168.12.137/demo
> http://192.168.12.137:80/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=demo%3Aparcellaire
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> xmlns:tiger="http://www.census.gov"
> xmlns:cite="http://www.opengeospatial.net/cite"
> xmlns:nurc="http://www.nurc.nato.int"
> xmlns:sde="http://geoserver.sf.net"
> xmlns:topp="http://www.openplans.org/topp"
> xmlns:it.geosolutions="http://www.geo-solutions.it"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:sf="http://www.openplans.org/spearfish"
> xmlns:ows="http://www.opengis.net/ows"
> xmlns:xlink="http://www.w3.org/1999/xlink"><gml:featureMembers/></wfs:FeatureCollection>
> Le 03/11/2010 08:38, Verena Diewald a écrit :
>> Hi,
>> Am 02.11.2010 22:19, schrieb zorg:
>>> Hello
>>> I have been testing mapbender for a month and I still have some
>>> question
>>> My map are using EPSG:2154 but by default mapbender only propose me
>>> EPSG:4326 to make it work I have use solution given in this post
>>> http://osgeo-org.1803224.n2.nabble.com/Problems-with-EPSG-td2059853.html
>>> (doing insert in the database).
>>> Is it the good solution
>> The point described in the post above is exactly what you have to do.
>>> second problem
>>> I've been trying to make the Spatial Queries with OGC WFS to work
>>> without any success (there is not error it just never found something)
>>> I using mapbender 2.6.2, GeoServer 2.0.2
>>> For the moment I have manage to work with the digitize module and
>>> gazetter module using wfs . I can create polygon without problem
>>> but after I can't find it with the spatial request module.
>> Can you give some more information? How does the filter statement for
>> the getFeature request look like? To get it, you can set the log
>> level in mapbender.conf to "notice", so you can then find the request
>> send to GeoServer in the mapbender log file in the log/ folder. Same
>> for the digitize transaction request. You could try to use the
>> getFeature xml post request or the transaction request in the
>> GeoServer demo request frontend to see what happens.
>> Best regards,
>> Verena
>>> hope someone can help
>>> I can give more specific information but I don't really know which
>>> one can help
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
