[Mapbender-users] problem with sld editor and geoserver
Michael Schulz mschulz at webgis.de
Wed Nov 10 06:31:58 EST 2010
no, I just need some time to setup a corresponding environment, don't
yet have a MB 2.6.2 with Geoserver 2.0 somewhere up and running ...
But, did you have a look in the php error log file?
I assume this is a bug, so it would be good if you could file a ticket
for it and assign it to me (mschulz).
Cheers, Michael
2010/11/10 zorg <zorg at probesys.com>:
> Hi
> Have I done something wrong or is this a bug
> do you need more information
> Thanks
> Le 09/11/2010 10:45, Michael Schulz a écrit :
>> Hi,
>> ok, thanks for that. Do you have assigned a wfs configuration to a wms
>> layer on which you want to use the SLD-Editor?
>> Cheers, Michael
>> 2010/11/9 zorg<zorg at probesys.com>:
>>> Hi
>>> everything is blank
>>> I have investigate a little and in fact when sld.main.php is call hte
>>> script
>>> doesnt work after line 96 (no error appear)
>>> I have try putting echo "test"; and it doesn't show after line 96 (hope
>>> i'm
>>> clear)
>>> /* Check for a related WFS featuretype */
>>> $wfs_conf_id = $dbutils->getLayerWfsConfId($_SESSION["sld_gui_id"],
>>> $layer_id);
>>> if ( $wfs_conf_id ) {
>>>        $featuretype_id = $dbutils->getWfsConfFeatureTypeId($wfs_conf_id);
>>>        $classWfsConf->getelements($featuretype_id);
>>>        $wfs_element = $classWfsConf->elements;
>>>        $fts =
>>> $styledlayerdescriptor->layers[0]->styles[0]->featuretypestyles[0];
>>>        $fts->setElementArray("element_id",$wfs_element->element_id);
>>>        $fts->setElementArray("element_name",$wfs_element->element_name);
>>> } else {
>>>        $wfs_element = false;
>>> Le 08/11/2010 20:11, Michael Schulz a écrit :
>>>> No, there's no other, my question was more whether the whole window
>>>> being completly empty/white or e.g. only the maps or whatever.
>>>> I'll have a look into that issue...  Cheers, Michael
>>>> 2010/11/8 zorg<zorg at probesys.com>:
>>>>> I using mapbender  2.6.2,  GeoServer 2.0.2
>>>>> Yes i'm talking about the sld editor popup (is there another one???)
>>>>> Le 08/11/2010 16:29, Michael Schulz a écrit :
>>>>>> Hi,
>>>>>> you mean the Sld-Editor popup window is completly empty? This is
>>>>>> Mapbender 2.6.2, right? Which Geoserver are you using?
>>>>>> Cheers, Michael
>>>>>>> Hi
>>>>>>> If i try to use sldeditor with geoserver wms I get a blank page with
>>>>>>> no
>>>>>>> error
>>>>>>> in the log i have this
>>>>>>> 2010.11.08, 15:33:25,Notice: class_locale: setting locale to fr
>>>>>>> 2010.11.08, 15:33:25,Notice: locale fr_FR.utf8 ok on linux
>>>>>>> 2010.11.08, 15:33:25,Notice: mb_validateSession.php: checking file
>>>>>>> /mapbender/sld/sld_main.php
>>>>>>> 2010.11.08, 15:33:25,Notice: gui id not set
>>>>>>> 2010.11.08, 15:33:25,Notice: gui id set to guiID: admin_en_services
>>>>>>> 2010.11.08, 15:33:25,Notice: mb_validateSession.php: GUI:
>>>>>>> admin_en_services,
>>>>>>> checking file /mapbender/sld/sld_main.php...session valid.
>>>>>>> If you have nay idea
>>>>>>> _______________________________________________
>>>>>>> Mapbender_users mailing list
>>>>>>> Mapbender_users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
