[Mapbender-users] problem with sld editor and geoserver
Michael Schulz mschulz at webgis.de
Wed Nov 10 07:49:12 EST 2010
ok, I could reproduce this behaviour with MB 2.7 also. This is a
problem of the SLD parser (it has nothing to do with the wfs_conf
assignment to a wms layer). The SLD-Editor has been initially
developed and tested for Mapserver. I have done some things to be able
to handle also GeoServer, but that was for GS 1.6/1.7 and especially
prior to GS supporting the getStyles request.
I think from GS 2 onwards the getStyles request is supported but the
SLD parser is currently not able to cope with it. This would mean it
will need to be overhauled for this requirement. Unfortunately I don't
have enough ressources at the moment to do this.
Zorg, do you have experience and/or ressources to look into this?
Cheers, Michael
2010/11/10 Michael Schulz <mschulz at webgis.de>:
> Hi,
> no, I just need some time to setup a corresponding environment, don't
> yet have a MB 2.6.2 with Geoserver 2.0 somewhere up and running ...
> But, did you have a look in the php error log file?
> I assume this is a bug, so it would be good if you could file a ticket
> for it and assign it to me (mschulz).
> Cheers, Michael
> 2010/11/10 zorg <zorg at probesys.com>:
>> Hi
>> Have I done something wrong or is this a bug
>> do you need more information
>> Thanks
>> Le 09/11/2010 10:45, Michael Schulz a écrit :
>>> Hi,
>>> ok, thanks for that. Do you have assigned a wfs configuration to a wms
>>> layer on which you want to use the SLD-Editor?
>>> Cheers, Michael
>>> 2010/11/9 zorg<zorg at probesys.com>:
>>>> Hi
>>>> everything is blank
>>>> I have investigate a little and in fact when sld.main.php is call hte
>>>> script
>>>> doesnt work after line 96 (no error appear)
>>>> I have try putting echo "test"; and it doesn't show after line 96 (hope
>>>> i'm
>>>> clear)
>>>> /* Check for a related WFS featuretype */
>>>> $wfs_conf_id = $dbutils->getLayerWfsConfId($_SESSION["sld_gui_id"],
>>>> $layer_id);
>>>> if ( $wfs_conf_id ) {
>>>>        $featuretype_id = $dbutils->getWfsConfFeatureTypeId($wfs_conf_id);
>>>>        $classWfsConf->getelements($featuretype_id);
>>>>        $wfs_element = $classWfsConf->elements;
>>>>        $fts =
>>>> $styledlayerdescriptor->layers[0]->styles[0]->featuretypestyles[0];
>>>>        $fts->setElementArray("element_id",$wfs_element->element_id);
>>>>        $fts->setElementArray("element_name",$wfs_element->element_name);
>>>> } else {
>>>>        $wfs_element = false;
>>>> Le 08/11/2010 20:11, Michael Schulz a écrit :
>>>>> No, there's no other, my question was more whether the whole window
>>>>> being completly empty/white or e.g. only the maps or whatever.
>>>>> I'll have a look into that issue...  Cheers, Michael
>>>>> 2010/11/8 zorg<zorg at probesys.com>:
>>>>>> I using mapbender  2.6.2,  GeoServer 2.0.2
>>>>>> Yes i'm talking about the sld editor popup (is there another one???)
>>>>>> Le 08/11/2010 16:29, Michael Schulz a écrit :
>>>>>>> Hi,
>>>>>>> you mean the Sld-Editor popup window is completly empty? This is
>>>>>>> Mapbender 2.6.2, right? Which Geoserver are you using?
>>>>>>> Cheers, Michael
>>>>>>>> Hi
>>>>>>>> If i try to use sldeditor with geoserver wms I get a blank page with
>>>>>>>> no
>>>>>>>> error
>>>>>>>> in the log i have this
>>>>>>>> 2010.11.08, 15:33:25,Notice: class_locale: setting locale to fr
>>>>>>>> 2010.11.08, 15:33:25,Notice: locale fr_FR.utf8 ok on linux
>>>>>>>> 2010.11.08, 15:33:25,Notice: mb_validateSession.php: checking file
>>>>>>>> /mapbender/sld/sld_main.php
>>>>>>>> 2010.11.08, 15:33:25,Notice: gui id not set
>>>>>>>> 2010.11.08, 15:33:25,Notice: gui id set to guiID: admin_en_services
>>>>>>>> 2010.11.08, 15:33:25,Notice: mb_validateSession.php: GUI:
>>>>>>>> admin_en_services,
>>>>>>>> checking file /mapbender/sld/sld_main.php...session valid.
>>>>>>>> If you have nay idea
>>>>>>>> _______________________________________________
>>>>>>>> Mapbender_users mailing list
>>>>>>>> Mapbender_users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Michael Schulz
in medias res
Schwimmbadstraße 2
More information about the Mapbender_users mailing list
