[Mapbender-users] using Mapbender 2.7 and http_auth
Michael Schulz mschulz at webgis.de
Tue Nov 30 05:40:08 EST 2010
Hi Armin,
one just needs to find the right documentation...
You just need to add this rewrite_rule to you apache configuration:
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
and then also php-cgi can use the http_auth mechanism.
One more question: while testing this with QGIS as client, I got the
qgis info, that the getmap url is different from the capabilities url.
When examining the XML it shows that the capabilities-URL uses the
http_auth address, while the getmap/getfeatureinfo/... use the
owsproxy URL. Is that intended behaviour?
Cheers, Michael
P.S.: After some more successfull testing I will add this information
to the wiki page.
2010/11/30 Michael Schulz <mschulz at webgis.de>:
> Hi Armin,
> after some more testing and searching through the various
> documentation on this subject, I'm pretty sure that it will work at
> the moment only on php as an apache-module environment: this is
> because with CGI the $_Server-Variables PHP_AUTH_* are not present.
> It seems that we would need some more apache rewriting to also enable
> the CGI case.
> Cheers, Michael
> Am 30. November 2010 07:45 schrieb Armin Retterath
> <armin.retterath at lvermgeo.rlp.de>:
>> should go to list ;-)
>> ----------  Weitergeleitete Nachricht  ----------
>> Betreff: Re: [Mapbender-users] using Mapbender 2.7 and http_auth
>> Datum: Dienstag 30 November 2010, 07:36:22
>> Von: Armin Retterath <armin.retterath at lvermgeo.rlp.de>
>> An: Michael Schulz <mschulz at webgis.de>
>> hi michael,
>> i think it is only a simple php script. this should run with php as cgi too.
>> but one thing is important: it use curl to do the connects to the external
>> webservices. the other ways of class_connector are not supported til now.
>> are you sure that you have a mb 2.7.X (e.g. trunk) installed on your system?
>> we tested the feature on fossgis 2010 and it works on the old telascience box
>> without problems.
>> maybe we can phone and give the solution back to the list ;-)
>> greetings from koblenz
>> armin
>> Am Montag 29 November 2010, um 15:33:14 schrieben Sie:
>>> Hi,
>>> I am experimenting with the new http_auth feature, to be able to serve
>>> the restful URLs of owsproxy/http_auth secured layers. I followed the
>>> wiki page instructions, created a user, generated the digest value,
>>> extended the apache configuration. When requesting such a http_auth
>>> layer I get a authentication dialog, but when entering the
>>> credentials, I keep getting back the authentication dialog
>>> ("mapbender_registry").
>>> Ok, is it correct that this festure is currently only supported when
>>> using php as an apache module and not as cgi?
>>> Cheers, Michael
>> Im Auftrag
>> Armin Retterath
>> Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
>> beim
>> Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
>> Ferdinand-Sauerbruch-Straße 15
>> 56073 Koblenz
>> Telefon 0261/492-466
>> Telefax 0261/492-492
>> http://www.geoportal.rlp.de
>> Im Auftrag
>> Armin Retterath
>> beim
>> 56073 Koblenz
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Michael Schulz
in medias res
Schwimmbadstraße 2
More information about the Mapbender_users mailing list
