[Mapbender-users] using Mapbender 2.7 and http_auth
Michael Schulz mschulz at webgis.de
Tue Nov 30 03:21:55 EST 2010
Hi Armin,
after some more testing and searching through the various
documentation on this subject, I'm pretty sure that it will work at
the moment only on php as an apache-module environment: this is
because with CGI the $_Server-Variables PHP_AUTH_* are not present.
It seems that we would need some more apache rewriting to also enable
the CGI case.
Cheers, Michael
Am 30. November 2010 07:45 schrieb Armin Retterath
<armin.retterath at lvermgeo.rlp.de>:
> should go to list ;-)
> ----------  Weitergeleitete Nachricht  ----------
> Betreff: Re: [Mapbender-users] using Mapbender 2.7 and http_auth
> Datum: Dienstag 30 November 2010, 07:36:22
> Von: Armin Retterath <armin.retterath at lvermgeo.rlp.de>
> An: Michael Schulz <mschulz at webgis.de>
> hi michael,
> i think it is only a simple php script. this should run with php as cgi too.
> but one thing is important: it use curl to do the connects to the external
> webservices. the other ways of class_connector are not supported til now.
> are you sure that you have a mb 2.7.X (e.g. trunk) installed on your system?
> we tested the feature on fossgis 2010 and it works on the old telascience box
> without problems.
> maybe we can phone and give the solution back to the list ;-)
> greetings from koblenz
> armin
> Am Montag 29 November 2010, um 15:33:14 schrieben Sie:
>> Hi,
>> I am experimenting with the new http_auth feature, to be able to serve
>> the restful URLs of owsproxy/http_auth secured layers. I followed the
>> wiki page instructions, created a user, generated the digest value,
>> extended the apache configuration. When requesting such a http_auth
>> layer I get a authentication dialog, but when entering the
>> credentials, I keep getting back the authentication dialog
>> ("mapbender_registry").
>> Ok, is it correct that this festure is currently only supported when
>> using php as an apache module and not as cgi?
>> Cheers, Michael
> Im Auftrag
> Armin Retterath
> Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
> beim
> Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
> Ferdinand-Sauerbruch-Straße 15
> 56073 Koblenz
> Telefon 0261/492-466
> Telefax 0261/492-492
> http://www.geoportal.rlp.de
> Im Auftrag
> Armin Retterath
> beim
> 56073 Koblenz
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
