Fwd: Re: [Mapbender-users] using Mapbender 2.7 and http_auth
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Tue Nov 30 01:45:43 EST 2010
should go to list ;-)
---------- Weitergeleitete Nachricht ----------
Betreff: Re: [Mapbender-users] using Mapbender 2.7 and http_auth
Datum: Dienstag 30 November 2010, 07:36:22
Von: Armin Retterath <armin.retterath at lvermgeo.rlp.de>
An: Michael Schulz <mschulz at webgis.de>
hi michael,
i think it is only a simple php script. this should run with php as cgi too.
but one thing is important: it use curl to do the connects to the external
webservices. the other ways of class_connector are not supported til now.
are you sure that you have a mb 2.7.X (e.g. trunk) installed on your system?
we tested the feature on fossgis 2010 and it works on the old telascience box
without problems.
maybe we can phone and give the solution back to the list ;-)
greetings from koblenz
armin
Am Montag 29 November 2010, um 15:33:14 schrieben Sie:
> Hi,
> I am experimenting with the new http_auth feature, to be able to serve
> the restful URLs of owsproxy/http_auth secured layers. I followed the
> wiki page instructions, created a user, generated the digest value,
> extended the apache configuration. When requesting such a http_auth
> layer I get a authentication dialog, but when entering the
> credentials, I keep getting back the authentication dialog
> ("mapbender_registry").
> Ok, is it correct that this festure is currently only supported when
> using php as an apache module and not as cgi?
> Cheers, Michael
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
Im Auftrag
Armin Retterath
beim
56073 Koblenz
More information about the Mapbender_users
