[Mapbender-users] using Mapbender 2.7 and http_auth
Michael Schulz mschulz at webgis.de
Mon Nov 29 09:33:14 EST 2010
I am experimenting with the new http_auth feature, to be able to serve
the restful URLs of owsproxy/http_auth secured layers. I followed the
wiki page instructions, created a user, generated the digest value,
extended the apache configuration. When requesting such a http_auth
layer I get a authentication dialog, but when entering the
credentials, I keep getting back the authentication dialog
("mapbender_registry").
Ok, is it correct that this festure is currently only supported when
using php as an apache module and not as cgi?
Cheers, Michael
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
