[Mapbender-users] Re: Mapbender 2.7.1 and GeoServer 2.0.3 - Connection Problem
sebweller sebweller at web.de
Tue Apr 26 03:26:16 EDT 2011
Hi Michele,
i have made a mistake with the coordinate system. I used EPSG:4281
(Palestine 1923) instead of the Jordan Transverse Mercator (EPSG 3066). I
corrected it within GeoServer and the Layerpreview still works fine.
Then i reloeded the WMS Capabilities into Mapbender (to gui1) and it does
not work. I took a look into the Metadata of the wms. there is a map prewiv,
which does not work,too. Under this Preview i ca select between different
projections. Either 3066 nor 4281 are listed there... Is this a Problem
within Mapbender or the Mapfile?
Mapfile:
&lt;!DOCTYPE WMT_MS_Capabilities SYSTEM
&quot;http://nwmp-geoserver:8080/geoserver/schemas/wms/1.1.1/WMS_MS_Capabilities.dtd&quot;&gt;
<WMT_MS_Capabilities version="1.1.1" updateSequence="175">
  <Service>
    <Name>OGC:WMS</Name>
    <Title>NWMP-GeoServer Web Map Service</Title>
    <Abstract>Map Server of the Ministry of Water and Irrigation
Jordan</Abstract>
    <KeywordList>
      <Keyword>WFS</Keyword>
      <Keyword>WMS</Keyword>
      <Keyword>GEOSERVER</Keyword>
    </KeywordList>
    <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:type="simple" xlink:href="http://nwmp-geoserver:8080/geoserver/wms"/>
    <ContactInformation>
      <ContactPersonPrimary>
        <ContactPerson>Sebastian Weller</ContactPerson>
        <ContactOrganization>GIZ-Jordan</ContactOrganization>
      </ContactPersonPrimary>
      <ContactPosition/>
      <ContactAddress>
        <AddressType/>
        <Address/>
        <City/>
        <StateOrProvince/>
        <PostCode/>
        <Country/>
      </ContactAddress>
      <ContactVoiceTelephone/>
      <ContactFacsimileTelephone/>
<ContactElectronicMailAddress>sebweller at web.de</ContactElectronicMailAddress>
    </ContactInformation>
    <Fees>NONE</Fees>
    <AccessConstraints>NONE</AccessConstraints>
  </Service>
  <Capability>
    <Request>
      <GetCapabilities>
        <Format>application/vnd.ogc.wms_xml</Format>
        <DCPType>
          <HTTP>
            <Get>
xlink:type="simple"
xlink:href="http://nwmp-geoserver:8080/geoserver/wms?SERVICE=WMS&amp;"/>
            </Get>
            <Post>
xlink:type="simple"
            </Post>
          </HTTP>
        </DCPType>
      </GetCapabilities>
      <GetMap>
        <Format>image/png</Format>
        <Format>application/atom xml</Format>
        <Format>application/atom+xml</Format>
        <Format>application/openlayers</Format>
        <Format>application/pdf</Format>
        <Format>application/rss xml</Format>
        <Format>application/rss+xml</Format>
        <Format>application/vnd.google-earth.kml</Format>
        <Format>application/vnd.google-earth.kml xml</Format>
        <Format>application/vnd.google-earth.kml+xml</Format>
        <Format>application/vnd.google-earth.kmz</Format>
        <Format>application/vnd.google-earth.kmz xml</Format>
        <Format>application/vnd.google-earth.kmz+xml</Format>
        <Format>atom</Format>
        <Format>image/geotiff</Format>
        <Format>image/geotiff8</Format>
        <Format>image/gif</Format>
        <Format>image/jpeg</Format>
        <Format>image/png8</Format>
        <Format>image/svg</Format>
        <Format>image/svg xml</Format>
        <Format>image/svg+xml</Format>
        <Format>image/tiff</Format>
        <Format>image/tiff8</Format>
        <Format>kml</Format>
        <Format>kmz</Format>
        <Format>openlayers</Format>
        <Format>rss</Format>
        <DCPType>
          <HTTP>
            <Get>
xlink:type="simple"
            </Get>
          </HTTP>
        </DCPType>
      </GetMap>
      <GetFeatureInfo>
        <Format>text/plain</Format>
        <Format>text/html</Format>
        <Format>application/vnd.ogc.gml</Format>
        <DCPType>
          <HTTP>
            <Get>
xlink:type="simple"
            </Get>
            <Post>
xlink:type="simple"
            </Post>
          </HTTP>
        </DCPType>
      </GetFeatureInfo>
      <DescribeLayer>
        <DCPType>
          <HTTP>
            <Get>
xlink:type="simple"
            </Get>
          </HTTP>
        </DCPType>
      </DescribeLayer>
      <GetLegendGraphic>
        <DCPType>
          <HTTP>
            <Get>
xlink:type="simple"
            </Get>
          </HTTP>
        </DCPType>
      </GetLegendGraphic>
      <GetStyles>
        <Format>application/vnd.ogc.sld+xml</Format>
        <DCPType>
          <HTTP>
            <Get>
xlink:type="simple"
            </Get>
          </HTTP>
        </DCPType>
      </GetStyles>
    </Request>
    <Exception>
      <Format>application/vnd.ogc.se_xml</Format>
      <Format>application/vnd.ogc.se_inimage</Format>
    </Exception>
    <UserDefinedSymbolization SupportSLD="1" UserLayer="1" UserStyle="1"
RemoteWFS="1"/>
    <Layer>
Jordan</Abstract>
      <SRS>AUTO:42001</SRS>
      <SRS>AUTO:42002</SRS>
      <SRS>AUTO:42003</SRS>
      <SRS>AUTO:42004</SRS>
      <SRS>EPSG:WGS84(DD)</SRS>
      <SRS>EPSG:2000</SRS>
      <SRS>EPSG:2001</SRS>
    ... i cut it her, because there are all epsg listed in here
      <SRS>EPSG:68206405</SRS>
      <SRS>EPSG:69036405</SRS>
      <SRS>EPSG:42302</SRS>
      <SRS>EPSG:42301</SRS>
      <SRS>EPSG:900913</SRS>
      <SRS>EPSG:45556</SRS>
      <SRS>EPSG:45555</SRS>
      <SRS>EPSG:54004</SRS>
      <SRS>EPSG:41001</SRS>
      <SRS>EPSG:42311</SRS>
      <SRS>EPSG:42310</SRS>
      <SRS>EPSG:18001</SRS>
      <SRS>EPSG:100003</SRS>
      <SRS>EPSG:42106</SRS>
      <SRS>EPSG:100002</SRS>
      <SRS>EPSG:42105</SRS>
      <SRS>EPSG:100001</SRS>
      <SRS>EPSG:42309</SRS>
      <SRS>EPSG:42104</SRS>
      <SRS>EPSG:42308</SRS>
      <SRS>EPSG:42103</SRS>
      <SRS>EPSG:42307</SRS>
      <SRS>EPSG:42102</SRS>
      <SRS>EPSG:42306</SRS>
      <SRS>EPSG:42101</SRS>
      <SRS>EPSG:42305</SRS>
      <SRS>EPSG:42304</SRS>
      <SRS>EPSG:42303</SRS>
      <LatLonBoundingBox minx="33.917" miny="36.065" maxx="35.901"
maxy="38.18"/>
      <Layer queryable="1">
        <Name>MWI:Azraq_GW_Basin</Name>
        <Title>Azraq_GW_Basin</Title>
        <Abstract/>
        <KeywordList/>
        <SRS>EPSG:3066</SRS>
        <LatLonBoundingBox minx="33.919" miny="36.065" maxx="35.882"
maxy="38.118"/>
        <BoundingBox SRS="EPSG:3066" minx="229759.986" miny="996244.164"
maxx="399307.515" maxy="1220566.368"/>
      </Layer>
        <Name>MWI:Azraq_GW_Basin_with_part_inside_syria</Name>
        <Title>Azraq_GW_Basin_with_part_inside_syria</Title>
        <Abstract/>
        <KeywordList/>
        <LatLonBoundingBox minx="33.917" miny="36.065" maxx="35.881"
maxy="38.18"/>
        <BoundingBox SRS="EPSG:3066" minx="229758.63" miny="996245.212"
maxx="399256.321" maxy="1227386.224"/>
      </Layer>
        <Name>MWI:Azraq_Surface_water_Basin</Name>
        <Title>Azraq_Surface_water_Basin</Title>
        <Abstract/>
        <KeywordList/>
        <LatLonBoundingBox minx="34.175" miny="36.614" maxx="35.901"
maxy="38.087"/>
        <BoundingBox SRS="EPSG:3066" minx="252119.403" miny="1056562.373"
maxx="401725.751" maxy="1217043.805"/>
      </Layer>
      <Layer queryable="0">
        <Name>testfiles</Name>
        <Title>testfiles</Title>
        <Abstract>Layer-Group type layer: testfiles</Abstract>
        <LatLonBoundingBox minx="33.829994891755064"
miny="36.030584591962146" maxx="35.91173106706805"
maxy="38.21517229456924"/>
        <BoundingBox SRS="EPSG:3066" minx="222279.693" miny="992698.05"
maxx="401990.004" maxy="1231292.339"/>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapbender-2-7-1-and-GeoServer-2-0-3-Connection-Problem-tp6293465p6304870.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
