[Mapbender-users] Re: Mapbender 2.7.1 and GeoServer 2.0.3 -
Connection Problem
roy
michele.rocc at gmail.com
Mon Apr 25 06:25:13 EDT 2011
2011/4/25 sebweller <sebweller at web.de>
> Hi Michele,
> I`ve loaded some polygon shapes into the GeoServer and gave them the
> "polygon" style... it's not looking awsome, but it works with open layers.
> Is it that what you meant?
yes that was ...
> So, my configuration steps have been the following:
> 1. I've installed Apache-PHP-PostreSQL and PostGIS extension
> 2. I've installed Mapbender on my working apache-php-postgresSQL(PostGIS)
> configuration
> 3. checked Mapbender Setup and Imagick was missing
> 4. installed ImageMagick-6.6.9-6-Q16-windows-dll.exe and copied the .dll i
> found on a website (i will have a look which website it was), renamed it
> and
> inserted it into the php/ext directory, added the dll to php.ini->
> everything is green in Mapbender now
> 5. Installed Geoserver on a VM
> 6. Configured Mapbender to connect via curl (because i couldn't get the
> capabilities)
> 7. tried the sample maps of geoserver in mapbender -> works fine
> 8. loaded own .shp Files into geoserver
> 9. tried to show them in mapbender -> it doesn't work
> So i think it has to be a geoserver based error, which results due to my
> configuration talent;)
looks to me a problem with your data config. on geoserver; as *step 7*
works,
network, geoserver and mapbender has to be ok ...
the problem seems to be on your step 8, what about coordinate system?
> Best regards
> Sebastian
> http://osgeo-org.1803224.n2.nabble.com/Mapbender-2-7-1-and-GeoServer-2-0-3-Connection-Problem-tp6293465p6302435.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110425/94d1d79a/attachment.html
More information about the Mapbender_users
