Fwd: Re: [Mapbender-users] Re: Mapbender 2.7.1 and GeoServer 2.0.3 -
	Connection Problem
    Armin Retterath
    armin.retterath at lvermgeo.rlp.de
    Tue Apr 26 04:27:01 EDT 2011
----------  Weitergeleitete Nachricht  ----------
Betreff: Re: [Mapbender-users] Re: Mapbender 2.7.1 and GeoServer 2.0.3 -
Connection Problem
Datum: Dienstag 26 April 2011, 10:24:53
Von: Armin Retterath <armin.retterath at lvermgeo.rlp.de>
An: sebweller <sebweller at web.de>
hi sebastian,
maybe you can add some entries like ("SRS_ARRAY", "4326, 31466, 31467, 31468,
25832"); in mapbender.conf. please uncomment this line and add the srs you
want to use. mapbender will calculate the bbox with the postgis functions and
store them into the database. after this you must re-register the service
(please delete the old and load it again) and may choose the crs from the
dropdown list.
and please check if your problems will occur with the default services like
demis and germany too!
services:
http://www.mapbender.org/Test
to get the url to your get map request which mapbender will send to the wms
for get the image, please use  under firefox the menu - Extras-
Seiteninformationen-Medien. You will see all links from the mapbender app and
the resulting images - please send the url of the main getmap request to the
list!
regards
armin
Am Dienstag 26 April 2011, um 09:58:10 schrieben Sie:
> Hi Armin,
> thank you for your help. Actualy i have deleted all other WMS from
> Mapbende, so my WMS is the only one. And i worked in "gui"... But Itried
> the steps you mentioned and the effect is the same: mygui is loading up
> properly, but i just get a white map (no "cannot  load image"- logo or
> something like this, just a white map).
> If i do admin1->EDIT GUI-WMS and try to change it to 3066 i can't. the list
> is limited to 4326...
> best regards
> Sebastian
> http://osgeo-org.1803224.n2.nabble.com/Mapbender-2-7-1-and-GeoServer-2-0-3
> -Connection-Problem-tp6293465p6304928.html Sent from the mapbender-users
> mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
Im Auftrag
Armin Retterath
LVermGeo RP
56073 Koblenz
More information about the Mapbender_users
