[Mapbender-users] Re: Mapbender 2.7.1 and GeoServer 2.0.3 -
Connection Problem
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Tue Apr 26 05:37:14 EDT 2011
hi sebastian,
your problem is the port of the geoserver:
see the capabilities:
maprequest: http://nwmp-geoserver:80/geoserver/wms?SERVICE=WMS&
on port 80 your geoserver will not listen!
please change this to port 8080 in the mapbender db - without update service -
or in your geoserver administration - than update!
i also think, that mapbender don't support the AUTO:42001 for wms_srs.
but this should not be your main problem.
regards
armin
Am Dienstag 26 April 2011, um 11:03:56 schrieb Sebastian Weller:
> Hi Armin,
> i uncommented the SRS-Array and added those projections i need. Then I've
> deleted the WMS and added it again. No effect...
> But I've recognised something inside the code which appears after you load
> a wms into mapbender:
> file:
> http://nwmp-geoserver:8080/geoserver/ows?service=wms&version=1.1.1&request=
> GetCapabilities id: 919
> version: 1.1.1
> title: NWMP-GeoServer Web Map Service
> abstract: Map Server of the Ministry of Water and Irrigation Jordan
> capabilitiesrequest: http://nwmp-geoserver:80/geoserver/wms?SERVICE=WMS&
> featureinforequest: http://nwmp-geoserver:80/geoserver/wms?SERVICE=WMS&
> gui_wms_mapformat: image/png
> gui_wms_featureinfoformat: text/html
> gui_wms_exceptionformat: application/vnd.ogc.se_inimage
> gui_wms_epsg: EPSG:4326
> wms_srs: AUTO:42001,...
> Maybe this info might help... how can i change the gui_wms_epsg?
> Best regards
> Sebastian
> PS.: The Server is not connected to the internet...
> On Tue, 26 Apr 2011 10:24:53 +0200, Armin Retterath
> wrote:
> > hi sebastian,
> > maybe you can add some entries like ("SRS_ARRAY", "4326, 31466, 31467,
> > 31468,
> > 25832"); in mapbender.conf. please uncomment this line and add the srs
> you
> > want to use. mapbender will calculate the bbox with the postgis
> functions
> > and
> > store them into the database. after this you must re-register the
> service
> > (please delete the old and load it again) and may choose the crs from
> the
> > dropdown list.
> > and please check if your problems will occur with the default services
> > like
> > demis and germany too!
> > services:
> > http://www.mapbender.org/Test
> > to get the url to your get map request which mapbender will send to the
> > wms
> > for get the image, please use under firefox the menu - Extras-
> > Seiteninformationen-Medien. You will see all links from the mapbender
> app
> > and
> > the resulting images - please send the url of the main getmap request to
> > the
> > list!
> > regards
> > armin
> > Am Dienstag 26 April 2011, um 09:58:10 schrieben Sie:
> >> Hi Armin,
> >> thank you for your help. Actualy i have deleted all other WMS from
> >> Mapbende, so my WMS is the only one. And i worked in "gui"... But
> Itried
> >> the steps you mentioned and the effect is the same: mygui is loading up
> >> properly, but i just get a white map (no "cannot load image"- logo or
> >> something like this, just a white map).
> >> If i do admin1->EDIT GUI-WMS and try to change it to 3066 i can't. the
> >> list
> >> is limited to 4326...
> >> best regards
> >> Sebastian
> >> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Mapbender-2-7-1-and-GeoServer-2-0-3
> >> -Connection-Problem-tp6293465p6304928.html Sent from the
> mapbender-users
> >> mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Mapbender_users mailing list
> >> Mapbender_users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users
