[Mapbender-users] question about overview
zorg zorg at probesys.com
Fri Aug 5 08:08:12 EDT 2011
HI
No it's not working  the overview is blank
The only workaroud I have found is to play with max scale min scale to
be sure that the map appear only with the overview
but I sure it must to have another solution
Le 05/08/2011 10:38, Vera Schulze a écrit :
> Hi Zorg,
> I think this is possible. Try this: Load the wms in position 0 and turn
> off all the layers. The wms should be still visible in the overview.
> HtH,
> Vera
> On Fri, August 5, 2011 8:22 am, zorg wrote:
>> Hello
>> I using the overwiew module and I wonder if there is a way to use a wms
>> in the overview different than in the map
>> For example
>> I have a map of a town street, street name , house, ...
>> but I only want to have in my overview the district limitation with a
>> different style  than the one in the map
>> hope I'm clear
>> Thank for your help
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> INTERGEO 2011
> 27.-29. September 2011 in Nürnberg
> Treffen Sie die WhereGroup in Halle 7, Stand E75
> www.intergeo.de
> WhereGroup GmbH&  Co. KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 29
> Fax: +49 (0)228 / 90 90 38 - 11
> Web: www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Geschäftsführer: Olaf Knopp, Peter Stamm
> Erweitern Sie Ihr Netzwerk über XING.
> Klicken Sie auf https://www.xing.com/go/invite/6149279.13610e
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users mailing list
