[Mapbender-users] question about overview
"Jäger, Frank (KRZ)" F.Jaeger at KRZ.DE
Fri Aug 5 08:52:29 EDT 2011
Hallo,
in the Overview the map is always visible as it is configured as "default".
Switching off layers in the browser only effects the mapframe.
So you have to configure a default for the Overview.
If you whish a different start-default for the mapframe, you must put the wms twice into the gui.
For the version which is "Only for Overview" you switch off the column "sel" in WMS-Configuration.
This WMS is not visible in TreeGDE.
Then you use a minScale that shows the Map only in Overview (~ Start-Scale-demon * 2).
Frank
> -----Original Message-----
> From: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of zorg
> Sent: Friday, August 05, 2011 2:08 PM
> To: mapbender_users at lists.osgeo.org
> Subject: Re: [Mapbender-users] question about overview
> HI
> No it's not working  the overview is blank
> The only workaroud I have found is to play with max scale min
> scale to be sure that the map appear only with the overview
> but I sure it must to have another solution
> Le 05/08/2011 10:38, Vera Schulze a écrit :
> > Hi Zorg,
> > I think this is possible. Try this: Load the wms in position 0 and
> > turn off all the layers. The wms should be still visible in
> the overview.
> > HtH,
> > Vera
> > On Fri, August 5, 2011 8:22 am, zorg wrote:
> >> Hello
> >> I using the overwiew module and I wonder if there is a way
> to use a
> >> wms in the overview different than in the map
> >> For example
> >> I have a map of a town street, street name , house, ...
> >> but I only want to have in my overview the district
> limitation with a
> >> different style  than the one in the map
> >> hope I'm clear
> >> Thank for your help
More information about the Mapbender_users mailing list
